Home > Td5 > Volumetric Sensor Part Number
Waldo
I have had my Td5 diagnosed by Land Rover for the alarm fault that started earlier this year (randomly going off for no apparent reason).
The upshot is they believe it is the volumetric sensor and it needs replacing.... For a total cost of almost £280
plus the diagnostic cost.
Personally I think it's a case of pop the old one out and put the new one in.
Whereas they think they need to remove the headlining to do it hence the high cost.
Therefore does anyone have the part number for the volumetric sensor for a:
Defender Td5 90XS (03 Reg)
or know where to source one
On another note LR gave me a free car valet whilst it was in for the diagnostic, it's the cleanest i've ever seen it.
It shines on the inside smells fresh out of the factory. So thumbs up to LR.
Regards
Will Defender 90 XS TD5 (03 Reg)
Post #314105 6th Mar 2014 10:44pm
Romadog
Brand Price Stock Callout Part Number Q-ty Part description From To
LAND ROVER 0 5 YWC102900LNF 1 SENSOR ULTRASONIC (V)TA977525 (V)5A701968
OR
LAND ROVER 0 5 YWC500470 1 SENSOR ULTRASONIC (V)5A701969
Not sure which suits your VIN number
Post #314109 6th Mar 2014 10:56pm
munch90
why do they say the headlining has to come down ?
is there a wiring problem ?
Post #314123 6th Mar 2014 11:19pm
Waldo
Thank you very much
No, they don't think there is a wiring problem
Just needs a new sensor apparently
Even asked if there was a wiring problem
Obviously the price will include labour which could be £100 easily Defender 90 XS TD5 (03 Reg)
Post #314130 6th Mar 2014 11:32pm
munch90
to change the sensor is 30 sec job
Post #314131 6th Mar 2014 11:34pm
landy andy
Does problem still happen? Could it be worth just disconnecting for a couple of days to test?
Andy
Post #314140 6th Mar 2014 11:46pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Yup try the disconnect first.
to remove it, you do not need to remove the headlining, unless there's a wiring fault.
i got mine off ebay for 25. Sometimes one from a defender does turn up. Not sure if the disco on will work, cos it's technically the same alarm ecu. anyone has some ideas if this is true? The defender has migrated, leaving the owner behind.
Post #314156 7th Mar 2014 12:28am
Waldo
So the sounders themselves are currently disconnected.
I've just removed the sensor and will connect the sounders up later tonight and fingers crossed all will remain silent.
I don't mind getting a new part and having to pay retail if it fixes the problem Defender 90 XS TD5 (03 Reg)
Post #314280 7th Mar 2014 3:19pm
Waldo
So the sensor has been disconnected for 24 hours now and there hasn't been any problems.
So I think that the sensor is almost certainly the problem.
Thanks for all the helps chaps
Post #314506 8th Mar 2014 5:36pm
