![]() | Home > Td5 > Volumetric Sensor Part Number |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Brand Price Stock Callout Part Number Q-ty Part description From To
LAND ROVER 0 5 YWC102900LNF 1 SENSOR ULTRASONIC (V)TA977525 (V)5A701968 OR LAND ROVER 0 5 YWC500470 1 SENSOR ULTRASONIC (V)5A701969 Not sure which suits your VIN number |
why do they say the headlining has to come down ?
is there a wiring problem ? |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Thank you very much
No, they don't think there is a wiring problem Just needs a new sensor apparently Even asked if there was a wiring problem Obviously the price will include labour which could be £100 easily Defender 90 XS TD5 (03 Reg) |
to change the sensor is 30 sec job
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5981 ![]() ![]() |
Does problem still happen? Could it be worth just disconnecting for a couple of days to test?
Andy |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
Yup try the disconnect first.
to remove it, you do not need to remove the headlining, unless there's a wiring fault. i got mine off ebay for 25. Sometimes one from a defender does turn up. Not sure if the disco on will work, cos it's technically the same alarm ecu. anyone has some ideas if this is true? The defender has migrated, leaving the owner behind. |
So the sounders themselves are currently disconnected.
I've just removed the sensor and will connect the sounders up later tonight and fingers crossed all will remain silent. I don't mind getting a new part and having to pay retail if it fixes the problem Defender 90 XS TD5 (03 Reg) |
So the sensor has been disconnected for 24 hours now and there hasn't been any problems.
So I think that the sensor is almost certainly the problem. Thanks for all the helps chaps Will Defender 90 XS TD5 (03 Reg) |
