![]() | Home > Technical > LR Safari 5000 driving spotlights - type of bulb !? |
| sherifsalem Member Since: 02 Jan 2013 Location: Porto Posts: 96
Hi Gents,
Bought this used Safari 5000 from ebay the other day, still did not fit because i want to know if it is worth swapping the original bulb. I have 2 X Orsam H3 night breaker, do you think it is better quality than the original? Does this spotlight support H3 or it is another type. It is just i wanted to known before hand if it is worth opening the spotlight or not. Happy Travel
www.thegippo.wordpress.com |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
I had some hella lamps which I think is the maker of the lr ones and they were h2 but check first
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
LR part number for bulb is 606178 and it looks exactly the same as an H3
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
As above h3
Thanx guys if this is the case probably the H3 Orsam night breakers are better than the originals as i have the night breakers for my driving Healamp.
Will keep you posted with final result.... Happy Travel www.thegippo.wordpress.com |
Just to recap
It is easy to disassemble and assemble , the bulb is indeed as you mentioned H3 , the genuine bulb is yellowish and I have swapped with H3 orsam night breakers and the result is much much better. The spotlight are recommended for what I want .....more light indeed My 2 cents Che Happy Travel www.thegippo.wordpress.com |
