Home > Technical > LR Safari 5000 driving spotlights - type of bulb !?
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
Hi Gents,
Bought this used Safari 5000 from ebay the other day, still did not fit because i want to know if it is worth swapping the original bulb.
I have 2 X Orsam H3 night breaker, do you think it is better quality than the original?
Does this spotlight support H3 or it is another type.
It is just i wanted to known before hand if it is worth opening the spotlight or not.
 Happy Travel
www.thegippo.wordpress.com
Post #313944 6th Mar 2014 1:25pm
munch90
I had some hella lamps which I think is the maker of the lr ones and they were h2 but check first
Post #313950 6th Mar 2014 1:57pm
Martin
Site Admin
LR part number for bulb is 606178 and it looks exactly the same as an H3 Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #313952 6th Mar 2014 2:02pm
mk1collector
As above h3
Post #313953 6th Mar 2014 2:06pm
sherifsalem
Thanx guys if this is the case probably the H3 Orsam night breakers are better than the originals as i have the night breakers for my driving Healamp.
Will keep you posted with final result.... Happy Travel
Post #313961 6th Mar 2014 2:46pm
sherifsalem
Just to recap
It is easy to disassemble and assemble , the bulb is indeed as you mentioned H3 , the genuine bulb is yellowish and I have swapped with H3 orsam night breakers and the result is much much better.
The spotlight are recommended for what I want .....more light indeed
My 2 cents
Che Happy Travel
Post #314961 10th Mar 2014 11:56am
