Home > Puma (Tdci) > Which Snorkel
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Which Snorkel
I am looking at fitting a Snorkel, I like the Mantec or Safari ones, looking for recommendations. Which one do you think is best..? 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #313114 3rd Mar 2014 3:16pm
Lewisgregory8
2014 Defender 90 Puma 2.2 HT Fuji White
I've just fitted a Mantec one. But you have do waterproof it. So seal the air box and pipes and also silicone where it mounts on the wing
Post #313120 3rd Mar 2014 3:47pm
Swollock
Thanks for that, one of my worries had been the affect on visibility when looking right say at a roundabout, in the pictures the mantec seems to stick further forward than the Safari one.
Tony 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #313122 3rd Mar 2014 4:08pm
rtm89
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
Is it just for show or are you planning on going wading?
Just a word of caution that if you have water up to the intake then the ecu will be in severe danger as it is mounted on the bulkhead and as far as I know can't be moved on the pumas.
Post #313123 3rd Mar 2014 4:10pm
I like the Safari personally, and it's designed for purpose. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #313124 3rd Mar 2014 4:19pm
Swollock
Its more of just in case so that I can go a little deeper without worrying too much, as I am sure you know sometimes its deeper than you thought. I have seen an ECU relocation loom, not sure if it was for the Puma though.
I have seen people end up in holes that being full of water with one wing under water tipped at 45 degrees and the air intake under the water line, so it is more of a worth while extra protection. 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #313126 3rd Mar 2014 4:28pm
Defender-Stu
If it was me it would be the Mantec Route Thumbs Up
Post #313135 3rd Mar 2014 4:53pm
Matthew_Mills
Has be be a standard LR for me... Cool
Visibility is marginally worse - about another 25% - e.g. take what you can't see now because of the post and add another Qtr... Not much more.
Post #313138 3rd Mar 2014 5:04pm
Lewisgregory8
Tony
I don't think it affects your vision at all, You can't even tell its there to be honest
Post #313149 3rd Mar 2014 6:05pm
K9F
http://www.defender2.net/forum/post32759.html#32759
http://www.defender2.net/forum/topic2105.html?highlight=trilby
http://www.defender2.net/forum/topic4955.html?highlight=safari If you go through life with your head in the sand....all people will see is an ar5e!!
Post #313155 3rd Mar 2014 6:23pm
SailingTom
Matthew, Ive just purchased a genuine Land Rover one like your for my next defender (at a particularly bargain price Wink ) Could you tell me how it secures to the wing. Do holes have to be drilled like I have done with safari ones in the past?
Cheers Tom Thumbs Up Defender puma dormobile camper
Post #313158 3rd Mar 2014 6:37pm
Schw8te
Germany 2013 Defender 90 Puma 2.2 SW Santorini Black
Just a mix. Mantec classic With Safari head Smile
Det locker bleiben
Post #313159 3rd Mar 2014 6:46pm
Matthew_Mills
Two holes drilled in the A post into which a bolt cuts it's own thread... Then two holes drilled in the wing with Rivnuts inserted - they are like a captive nut crossed with a rivet!
See in striations below: -
Post #313162 3rd Mar 2014 6:54pm
Lewisgregory8
instructions are the same as the Mantec RAI
Post #313167 3rd Mar 2014 7:01pm
Matthew_Mills
Yep the LR version is made by Mantec for LR...
Post #313169 3rd Mar 2014 7:04pm
