![]() | Home > Puma (Tdci) > Which Snorkel |
Lewisgregory8 Member Since: 17 Sep 2012 Location: Durham Posts: 395 ![]() ![]() |
I've just fitted a Mantec one. But you have do waterproof it. So seal the air box and pipes and also silicone where it mounts on the wing
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 285 ![]() ![]() ![]() |
Thanks for that, one of my worries had been the affect on visibility when looking right say at a roundabout, in the pictures the mantec seems to stick further forward than the Safari one.
Tony 2008 Defender 110 XS CSW Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
rtm89 Member Since: 14 May 2013 Location: North Yorkshire Posts: 258 ![]() ![]() ![]() |
Is it just for show or are you planning on going wading?
Just a word of caution that if you have water up to the intake then the ecu will be in severe danger as it is mounted on the bulkhead and as far as I know can't be moved on the pumas. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
I like the Safari personally, and it's designed for purpose. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Its more of just in case so that I can go a little deeper without worrying too much, as I am sure you know sometimes its deeper than you thought. I have seen an ECU relocation loom, not sure if it was for the Puma though.
I have seen people end up in holes that being full of water with one wing under water tipped at 45 degrees and the air intake under the water line, so it is more of a worth while extra protection. 2008 Defender 110 XS CSW Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
If it was me it would be the Mantec Route
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 ![]() ![]() |
Has be be a standard LR for me...
![]() Visibility is marginally worse - about another 25% - e.g. take what you can't see now because of the post and add another Qtr... Not much more. ![]() Click image to enlarge |
I don't think it affects your vision at all, You can't even tell its there to be honest |
http://www.defender2.net/forum/post32759.html#32759
http://www.defender2.net/forum/topic2105.html?highlight=trilby http://www.defender2.net/forum/topic4955.html?highlight=safari If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1732 ![]() ![]() |
Matthew, Ive just purchased a genuine Land Rover one like your for my next defender (at a particularly bargain price ![]() Cheers Tom ![]() |
Schw8te Member Since: 03 Jun 2012 Location: NRW Posts: 27 ![]() ![]() ![]() |
Just a mix. Mantec classic With Safari head
![]() ![]() Click image to enlarge Cheers Det locker bleiben |
Two holes drilled in the A post into which a bolt cuts it's own thread... Then two holes drilled in the wing with Rivnuts inserted - they are like a captive nut crossed with a rivet! See in striations below: - ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
instructions are the same as the Mantec RAI
Yep the LR version is made by Mantec for LR...
