![]() | Home > Technical > Defender TD5 wont start |
| ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221
Does the self prime process work on defenders the same as on discos? If so try that, I.e. Ignition on, pump the throttle peddle 5 or 6 times and the system goes into purge mode - pumps fuel about to get air out of the system - you should be able to hear the pump clearly during this. If you can't that's probably the problem. It wasn't me!
| Paulpen Member Since: 01 Mar 2014 Location: Somerset Posts: 20
Did give that a go and still no sound from the pump - wether thats because there is a pump issue or because thats not working on this one im not sure
Power at the interia switch and bypassing the switch makes no difference.
Lift pump works with a direct earth and live. Also kept tracing it all the way back to the plug by the expanson tank and can still run it from there. The traced it to the green relay in the centre console and can run it from there. The relay also tests ok but its not getting triggered at all. Traced from the green relay to the ECU and can manually run the pump with a 12v and earth from the ECU connector so either the ECU is not switching earths / lives correctly or it has none going into it to be able to switch. It starts to try and run on easy start however even if I have the pump running and crank it over it dont even try so guess the ECU is not opening the injectors either ? |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
With your description of damp etc plus all the rain we have had I think I would start by checking the ECU's earth.
Maybe worth running a new one to a known good earth point. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Have tried reearthing the ECU case and the 10mm bolt to the connector near it under the drivers seat.
I have 5 earths at the ECU plug (Black plug). All 5 are black wires at one end of the plug... |
OK.
I take it the battery is OK, TD5's are very touchy if the voltage is a bit low ? Also take a look at the crank sensor, doubt that it is that if the pumps not running but has got to be worth checking. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
12.4 - 12.6v showing between the terminals
What should I be looking for at the crank sensor and where is it ? |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
on top of the bellhousing at the 1 o clock position as seen from the rear of the vehicle. it is approx 50mm behind the cylinder head.
on the Defender it is easy to get to once you get that thick rubber pipe out of the way. Its really a very simple job, 2nd time round took me 3 minutes. Remove the pipe that connects the air intake to the air filter Remove the crank position sensor (7mm 1/4" socket works best) Disconnect the plug (I found its easier to remove the CPS first, then remove the connector. Install reverse above. |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Mine did that a few years ago.
Left it in a carpark for about half an hour and it wouldn't start when we came back. I couldn't sort it. An AA man couldn't sort it so we ordered a relay truck. Two hours later I tried it and it started perfectly. Never done it since. ![]() Last edited by Laurie on 2nd Mar 2014 6:40pm. Edited 1 time in total |
On top of the bellhousing at the 1 o clock position as seen from the rear of the vehicle.
Make sure the cable is OK and once removed that the end of the sensor has not been damaged. Mine had the small spacer shim missing and that gave running problems. If the sensor is shot the vehicle will not start. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Ill give that a shot tomorrow evening then - other than physical damage is there a voltage I should see at the plug and a resistance accross the sensor ?
Good call on the crank sensor. Iirc it's one of the few things that stop the engine firing. I'd forgotten about it, but I always carry a spare. It's cheap enough, and an easy fix, and if it doesn't work you have a spare if/when it is needed. It wasn't me!
| bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205
If the temp gauge is reading high and no fuel pump you have an earth issue, usually the connectors on the relay under the seat or ecu internal failure. However, I have seen one where the earth wire between the inertia switch and the main ecu relay under the seat was broken. Put in an overlay harness and it fired up straight away
Dont suppose you know what wires of the under seat relays should have earths ?
There are only two relays under there (one yellow and one black). Have tested both for operation off the car and both work. Unsure what readings I sould get at the pins though..... |
