Home > Td5 > Wheres my fuel going?
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
Hi all, i know this is a frequently asked question but i need some advice, Back in may i got my 03 td5 90 and was really hay when i was getting a steady 30mpg every day, i have done a few things since the
Removed iforwilliams top
fitted light bar
fitted 265/75/16 road tires (apposed to 205's)
fitted a snorkle
i now cannot get about 24mpg no matter how i try. i apreciate these mods will have an effect but 100 miles er tank?!! anyone got any ideas how i can claw back some miles? i'm only an apprentice so i cant afford to be losing money cheers ED
Post #312110 27th Feb 2014 5:44pm
JWL
Changing the tyres will have affected the milometer, the bigger diameter will give a lower mileage reading than the 205's and if you have based your calculations on the clock on the speedo then that could account for the discrepancy.
Post #312115 27th Feb 2014 6:02pm
VeeTee
Netherlands
Assuming you first had 205/80x16 and now 265/70x16, the difference in circumference is 5.86%. So in reality you do 24 x 1.0586 = 25.4 mpg.
You loose some efficiency because of the increased resistance of the bigger tyres, and some is lost because of the modified air intake and light bar. My 300 Tdi has 265/70x16 tyres also, as wel as a snorkel and roofrack. In cold weather in the winter approx. 25 mpg is normal, in the summer it is a bit better, approx. 28 mpg. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #312150 27th Feb 2014 8:27pm
landy andy
What miles per tank are you getting please.
Andy
Post #312175 27th Feb 2014 9:35pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
My Td5 does about 285 miles to the fuel light coming on about 310 to getting nervous ! 2005 Td5 90 XS
Steve
Post #312179 27th Feb 2014 10:00pm
Millsy94
You find summer better than winter for mpg? I was getting 360 to a tanks now 240-280 hope it'll return in the spring also got overdrive but hoping that'd improve it
Post #312183 27th Feb 2014 10:22pm
Millsy94
is your 90 standard?
Post #312186 27th Feb 2014 10:29pm
Lou Sparts
Yes bog standard as far as i know, Running 235 85 16 BFG AT,s mostly just local running around to and from work.
Does less if used on motorway at speed as you would expect. 2005 Td5 90 XS
Steve
Post #312188 27th Feb 2014 10:34pm
Millsy94
Same rolling circumference as me then really, I don't do too much motorway speed though I did find doing 95 really sunk the fuel may disconect snorkel to see any change
Post #312190 27th Feb 2014 10:37pm
Lou Sparts
oh yes forgot to mention i have an RAI. 2005 Td5 90 XS
Steve
Post #312193 27th Feb 2014 10:53pm
I.AM_a driver
Scotland 2002 Defender 90 Td5 CSW Oslo Blue
I get about 300 ish miles out of a tank, but I've a Patriot rack and safari RAI, but standard engine/gearbox/suspension with 265x75r16 ATs.
I'd have expected better mpg in the winter, due to more dense fuel when dispensed, and more dense air for the combustion cycle, but these are Land Rovers after all. Mark S
CONVOY for HEROES
www.facebook.com/convoy4heroes
www.lothian4x4response.org
Td5 90
Thread in 'My Defender' Forum
Post #312198 27th Feb 2014 11:07pm
VeeTee
Netherlands
fuel economy winter vs summer Cheers, Vincent
MySite
Post #312201 27th Feb 2014 11:14pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
I obviously need to slow down. I am happy with 20mpg. www.td5.org
Post #312212 27th Feb 2014 11:44pm
JWL
I'm with Mark with the fuel consumption being better in the colder weather in the winter, the whole object of our diesel engines having intercoolers fitted is to try to keep the air temperature cooled after being compressed with the turbo. So if the ambient air is cooler in the first place then there is hope that the air entering the combustion chamber is cooler than in summer, not by a huge amount but cooler. There is the chance of wetter conditions which does make a difference, but it can be noticeable on a dry cold frosty morning when your motor seems to run better.
The link posted above is geared mainly to petrol and lpg engines, and Americans.
Post #312221 28th Feb 2014 12:32am
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
My TD5 did 25mpg whether I cained it, sat at 50, Summer, Winter, off road, you name it, it averaged 25mpg all the time. I really found it bizarre, I calculated every single tankful, and it ranged from about 24.7 to 25-8mpg. That is obviously within a margin of error, but basically it was 25.
My 300 on the other hand fluctuates wildly. In the Summer, I was getting 28-29 on almost every trip. I did not have a roof rack on back then though. In the winter, before roof rack, I had about low 27s, with roof rack it's about 26. I commute regularly through several villages, with a lot of 30 limits, slowing down for tractors, which probably brings it down a bit more, but on a 500 mile run up to Newcastle and back in November, (took rack off for the trip) I estimate the motorway journey, I got about 29.8. 1998 110 300Tdi White Hard Top
Post #312222 28th Feb 2014 12:33am
