![]() | Home > Off Topic > Not only Defenders are a very easy steal.... |
Poor BMW owner was able to take pictures with telelens how his relatively recent BMW was stolen within 1 minute.
Happened in The Netherlands and the movie comments are in Dutch language, but still interesting to see how easy it apparently is. So not only Defenders...... In a nutshell, the comments are that the owners parked their BMW 320 and walked up a hill, smaller white Beemer parks behind them and touches their 320, 2 guys get out apparently checking if they caused any damage but in reality were checking if all was clear..., they both walk to the side of his car and owner thinks they are going to put a note with their name and phone number behind his wiper ![]() ![]() So not only Defenders. ![]() ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 ![]() |
Google "BMW stolen without keys" and you might form a view that they're easier to steal than a Defender...
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
Don't get it. How did they steal the car? Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
By using a cloned key most likely. A blank programmed in the car being stolen through the OBD port.
As I understand it though there should have been a software change to prevent this so if it had been serviced that would be impossible. www.td5.org |
make the obd socket live with ign on only ,not live all the time or have a switch ( hidden ) on the neg feed
a programmer cant work then |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Reroute the original one to another place and place a dummy with enough volt running through it to burn the thief's laptop?
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Or even re-route and hide the OBD socket and have an immobiliser act as a break in the circuit of the socket, onlt making it live when needed by the garage or if you have one, a scanguage. Oh and as you say, wire up a fake OBD to the battery.
only thing with making obd socket live only with ign is some dianostic tools need you to switch on then off then on etc to talk to ecus .
move obd or switch in earth would be better . put a dummy one back in orringal hole so any one trying will think its just not working usual thing applys if only you know is best |
so, if it's that easy why do land rover not do it ?
Same reason they don't make them waterproof or secure the bonnets and doors I suppose!
Absolutely. I have a very complicated system in place now. Takes me 20 mins to explain the garage. Just hope the fitters are trustworthy ![]() |
to be honest I would rather it act normal rather then let anyone know
A thief wouldn't know, its vanilla unless you know about it. Totally passive too.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
Just chop the OBD socket off, solder on *another* type of socket, and make up an adaptor with the OBD socket soldered to the mating new plug to suit the one you just fitted.
Keep said lead out of the vehicle. then no-one can plug anything in! |
