Home > Off Topic > Not only Defenders are a very easy steal....
Page 2 of 2 <12
munch90
some run scangauge etc and need obd socket
Post #311295 24th Feb 2014 4:46pm
martinfiattech
Or even easier if your really worried. Insulate, remove, can / k line from ecu multy plug or 10as unit so no comms to diag socket. All looks normal but no comm to ecus.
Post #312912 2nd Mar 2014 4:54pm
ericvv
Also the most recent versions of factory alarms seem not worth much.....
Someone I know in Antwerp just has his 1 year old Evoque stolen there. Was parked on the street,... and then not anymore. Crying or Very sad You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #318530 23rd Mar 2014 10:13pm
Skeggy 90
England 2011 Defender 130 Puma 2.4 SW Bali Blue
Key programming for later Land Rovers now has to be done by the dealer network as L/R have removed it from IDS for non franchised dealers. Defenders can be programmed by a lot of hand held diagnostic machines, you can even reprogram the EKA code on most models. A lot of vehicles are stolen using ECU's without immobilisers that just need plugging in to start the engine, scary stuff !
Post #318573 23rd Mar 2014 11:36pm
Page 2 of 2 <12
