![]() | Home > Td5 > Mileage! |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
What constitutes "high mileage"?
And how high can the mileage go on these lumps before major heart surgery is required? |
160k plus on mine Ozzy, no real issues just fuel pressure regulator and a couple of sets of injector washers and seals, the set I put in have lasted longer than the ones the so called specialist Independant put in at an exhorbitant price.
Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98 ![]() ![]() ![]() |
126 k on mine, and still going well.
Did the injector loom and FPR at about 80k. I do the oil and all filters annually, it's decat and EGR free. It seems to have built a reputation for longevity , generally. |
Birdy Member Since: 07 Oct 2011 Location: CĂ´te d'Azur Posts: 886 ![]() ![]() ![]() |
With today’s materials technology and assembly by robots with components matched for tolerance, with regular oil changes there’s absolutely no reason why a modern engine should EVER need “major heart surgery”; assuming, of course, parts are even available.
I sold my LHD 2001 TD5 after ten years with 150,000 on the clock, it’s still going strong being used to tow classic cars all over Europe, so I shudder to think what the mileage is now! Engine-wise the water pump has been replaced, and the oily loom changed as a prevention rather than an actual fault. If my current one gives half as good service I’ll be more than satisfied. Peter |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 ![]() ![]() |
My td5 Disco is currently on 208000, emissions were well within the limits at the last MoT. I know the head gasket was done at approx 120000 due to the plastic dowels, it's on it's third FPR and has had a new water pump and camcover gasket / injector harness. The EGR fell off soon after I got it.
I generally average 50 - 60 mph and it returns just over 30 mpg. |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 371 ![]() ![]() ![]() |
Mines nearly 10 years old and today passed 224,000 miles.
New gearbox (notchy), transfer box (leaky) and diffs (howling) & radiator (leaking) at 130k. New VNT turbo at 160k, with remap from IRB Developments. Lovely ![]() New intercooler (JE Engineering one split and playing the trombone), clutch and dual mass flywheel (noisy) at 210k. I replace the injector loom every couple of years as a precaution and I've recently fitted a new fuel pressure regulator. And I put fuel in it. Lots and lots of fuel ![]() Green Goddess - 1998 Defender 110 300tdi |
