![]() | Home > Td5 > Mileage! |
| ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221
What constitutes "high mileage"?
And how high can the mileage go on these lumps before major heart surgery is required? |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
160k plus on mine Ozzy, no real issues just fuel pressure regulator and a couple of sets of injector washers and seals, the set I put in have lasted longer than the ones the so called specialist Independant put in at an exhorbitant price.
| Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98
126 k on mine, and still going well.
Did the injector loom and FPR at about 80k. I do the oil and all filters annually, it's decat and EGR free. It seems to have built a reputation for longevity , generally. |
| Birdy Member Since: 07 Oct 2011 Location: CĂ´te d'Azur Posts: 887
With today’s materials technology and assembly by robots with components matched for tolerance, with regular oil changes there’s absolutely no reason why a modern engine should EVER need “major heart surgery”; assuming, of course, parts are even available.
I sold my LHD 2001 TD5 after ten years with 150,000 on the clock, it’s still going strong being used to tow classic cars all over Europe, so I shudder to think what the mileage is now! Engine-wise the water pump has been replaced, and the oily loom changed as a prevention rather than an actual fault. If my current one gives half as good service I’ll be more than satisfied. Peter |
| grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153
My td5 Disco is currently on 208000, emissions were well within the limits at the last MoT. I know the head gasket was done at approx 120000 due to the plastic dowels, it's on it's third FPR and has had a new water pump and camcover gasket / injector harness. The EGR fell off soon after I got it.
I generally average 50 - 60 mph and it returns just over 30 mpg. |
| nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 371
Mines nearly 10 years old and today passed 224,000 miles.
New gearbox (notchy), transfer box (leaky) and diffs (howling) & radiator (leaking) at 130k. New VNT turbo at 160k, with remap from IRB Developments. Lovely New intercooler (JE Engineering one split and playing the trombone), clutch and dual mass flywheel (noisy) at 210k. I replace the injector loom every couple of years as a precaution and I've recently fitted a new fuel pressure regulator. And I put fuel in it. Lots and lots of fuel Green Goddess - 1998 Defender 110 300tdi |
| All times are GMT |
