Home > Technical > Land Rover Tow Balls
Alicat
My Defender was fitted at the dealer with a LR drop plate and tow ball. Is the LR tow ball compatible with ALKO stabilisers, or do I need to change it for an ALKO compatible one?
Thanks
Tony
Post #308197 14th Feb 2014 11:28pm
mick
Mine is got a bit of extra neck on it measure it to be sure
Post #308204 14th Feb 2014 11:45pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Ideally you need the Alko ball which has a longer neck to fit the Alko hitch with the stabiliser fitment. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #308205 14th Feb 2014 11:50pm
Laurie
Try it.
Mine had an OE towball fitted. Takes out Alko hitch on the caravan easily.
Post #308207 14th Feb 2014 11:58pm
The LR ball is not designed to be Al-Ko compatible and under some extremes of articulation the coupling can bind on the ball. A genuine Al-Ko ball only costs �26.95 (I bought one this afternoon) and is cheap compared the the cost of repairing a damaged coupling.
Post #308215 15th Feb 2014 12:16am
mick
�12.95 from towsure
Post #308247 15th Feb 2014 9:25am
munch90
not a answer or help
we had a transit in during the week where the tow ball itself only had one bolt in it and that was loose allowing the ball to twist round ,, but still had a trailer (not a small one either ) on it when they pulled up and asked if it was ok to use !!!!.
Post #308260 15th Feb 2014 10:16am
Alicat
Thanks all, a mixed response then, but as an ALKO unit is not that expensive then it looks like that is the way to go.
Thanks all
Tony
Post #308282 15th Feb 2014 12:26pm
