![]() | Home > Maintenance & Modifications > I feel like an archeologist! |
| Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788
it depends if you can get it up on some decent ramps or something similar?
i use a heated jet wash and stand underneath for a good while! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Steam cleaner.
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435
Somebody local has a steam cleaner and charges £25 for a good going over, but is it ok to use hot steam underneath? Will it damage anything, and will surely it will remove any grease/oil that's 'meant' to be there?
Modern grease is high melting point (HMP)
Won't do any harm. ![]() |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Keep crawling underneath with a hose pipe AND jetwash,took me months to get rid of all the crap underneath mine,soon as you think you cleaned it you spot more mud,problem is you cant see the mud when it's wet,crawling underneath gets you familiar with all the mud traps which will help should you decide to Dinotrol/Waxoil it..
As fer removing grease etc. usual common sense, don't aim directly at rubber seals electrical connectors and you should really be re-greasing you props anyways. Pov.spec,ftw. 2006, 110,TD5. |
| Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
An idiot/unskilled operative can do a lot of damage with a steam cleaner or high pressure washer. Pointing it in the wrong places can drive moisture into places that normally would repel the ingress of water/moisture. I've used one high pressure system that can remove paint as well as road crud ............. hope your £25 doesn't buy you trouble. If you are anxious - do it yourself and be gentle if it's not really baked on. |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
places to avoid with a steam cleaner are; axle ends, propshaft ends, fuel tank and don't get too close to the engine and gearbox. the rest should be fine - with a steamer there is less actual pressure but a lot more heat which can still do damage.
take your time and the results will be well worth it 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
Mine was full of mud when I bought it... and grass, and trees... I changed the chassis instead
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243
Call The Time Team-they might find a Series1 underneath the mud
