Home > Maintenance & Modifications > I feel like an archeologist!
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I've spent the last few hours with a screw driver, brush and a paint scraper trying to clean up the chassis on my pickup.
I bought it last week, very low miles and all solid underneath, it's only done a few hundred miles in the last 7 years, but it looks like the previous owner (of 7 yrs) used it in a field and didn't wash it afterwards, very dry and powdery, just a few clumps here and there, but as Defender seem to be built with mud collection in mind, it's hard to get to all the places.
Is there a proven way of removing mud from the chassis etc? I don't mind spending time doing it, I'd rather do it properly than just try and blast it off with a jet washer, anyone had good results?
Post #307015 10th Feb 2014 11:43pm
Cheshire110
it depends if you can get it up on some decent ramps or something similar?
i use a heated jet wash and stand underneath for a good while! Cheers, David
Post #307022 10th Feb 2014 11:52pm
Laurie
Steam cleaner.
Post #307025 10th Feb 2014 11:56pm
Lambley
Somebody local has a steam cleaner and charges £25 for a good going over, but is it ok to use hot steam underneath? Will it damage anything, and will surely it will remove any grease/oil that's 'meant' to be there?
Post #307029 10th Feb 2014 11:58pm
Laurie
Modern grease is high melting point (HMP)
Won't do any harm.
Post #307032 11th Feb 2014 12:05am
jimbob7
Keep crawling underneath with a hose pipe AND jetwash,took me months to get rid of all the crap underneath mine,soon as you think you cleaned it you spot more mud,problem is you cant see the mud when it's wet,crawling underneath gets you familiar with all the mud traps which will help should you decide to Dinotrol/Waxoil it..
As fer removing grease etc. usual common sense, don't aim directly at rubber seals electrical connectors and you should really be re-greasing you props anyways. Pov.spec,ftw. 2006, 110,TD5.
Post #307034 11th Feb 2014 12:14am
Cuthbert
An idiot/unskilled operative can do a lot of damage with a steam cleaner or high pressure washer. Pointing it in the wrong places can drive moisture into places that normally would repel the ingress of water/moisture.
I've used one high pressure system that can remove paint as well as road crud ............. hope your £25 doesn't buy you trouble. If you are anxious - do it yourself and be gentle if it's not really baked on.
Post #307035 11th Feb 2014 12:22am
grafty99
places to avoid with a steam cleaner are; axle ends, propshaft ends, fuel tank and don't get too close to the engine and gearbox. the rest should be fine - with a steamer there is less actual pressure but a lot more heat which can still do damage.
take your time and the results will be well worth it Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #307070 11th Feb 2014 9:06am
GUM97
Mine was full of mud when I bought it... and grass, and trees... I changed the chassis instead Whistle An engine to TDi for!
Post #307200 11th Feb 2014 6:21pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Call The Time Team-they might find a Series1 underneath the mud Thumbs Up
Post #307216 11th Feb 2014 6:49pm
