![]() | Home > Maintenance & Modifications > Can anyone recommend some GOOD number plate adhesive? |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Use decent thick double sided tape.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
Just regular stuff? What I had was adhesive foam but it's a load of rubbish, it doesn't even work in the house much less outside.
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
^^That's what I've always used. You can't get it off when you want to
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264
Stupid question maybe but did you warm up the tape before applying
| sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568
3m VHB tape but make sure you get it straight first time because the plate is not coming back off in one piece
| CARMARK2014 Member Since: 28 Dec 2013 Location: SHEFFIELD Posts: 57
You could try no nails double sided tape i put mine on with this stuff and canrt get then off without braking the number plate. Defender 110
| rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 891
Selllotape "outdoor sticky fixers"
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2279
Ask the salesman at your dealer . He's always gotta big roll in his drawer . That's where I got mine Free
No I didn't warm it up but I can tell its useless, I found a use inside the house too and that came off.
To be honest the more per permanent stuff would be best because I don't want it to come off. The white foam like tape seems best, that's what I had on there originally and never budged. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2155
Had to do move my front number plate when I fitted the day light running bumper and I'm embarrassed to say I got some number plate tape for a couple of pounds from Halfords and it works a treat.
Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
External grade no more nails tape
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Steve,
I have some 3M Jelly Apetape, industrial grade, surface it goes on MUST be clean, gently warm tape and adhere. Very expensive and cost prohibitive for what you need. As ever 'pm' me your details again and I'll send you a metre or so if it's any help. Treat every day as if it is your last....one day you will be right!! |
Mal, if you are sure that would be most kind. It is only the rear plate my front is fixed on with screws. ____\We|Will|Win/___
No problems Steve. 'PM' me your address again please (I'll keep it this time) and I'll get some in the post tomorrow. Just chalk it up as another beer you owe me sometime.
Keep it in the plastic bag when you're not using it or it becomes contaminated by any particles it comes into contact with as everything sticks to it. Treat every day as if it is your last....one day you will be right!! |
| All times are GMT |
