Home > In Car Electronics > Carling switches vs Standard switches
Cheshire110
so I'm seriously trying to figure out how to fit a double DIN to my defender (a whole other topic)
and i was contemplating moving the switches which need to be relocated to a puma pod rather than cutting a big hole in the dash for the replacement switch panel
I've got 2 carling switches in my puma pod so far and they're good, so i was wondering if it would be too much of a job / if it is possible to replace the standard switches with carling switches.
i think id leave the 2 heated screens standard, and so id need to replace the following switches with carling ones:
- rear squirter and rear wiper (mud carling equivalent: http://www.mudstuff.co.uk/products/electri...witch.html
- hazard lights (mud carling equivalent here: http://www.mudstuff.co.uk/products/electri...witch.html
- rear fog light (mud carling equivalent: EDIT: turns out mud sell an actual fog switch - http://www.mudstuff.co.uk/products/electri...witch.html )
3 or 4 carlings will fit fine in the puma pod i already have, but I'm wondering if the wiring will work? i know the standard LR switches are some different type of switch but i don't see why they couldn't work?
mud sell carling switches for Hazards, Rear wash/wipe etc and a range of on/off and momentary switches so I'm sure i could get whichever type i need but id need a bit of advice on wiring probably?
thanks in advance! David Cheers, David
Post #303406 30th Jan 2014 1:53pm
Firstly get them from Tim at the Mobile centre (they will be switched the UK way then)
Nothing wrong at all with the Mudstuff apart from they are switched for the US market if you have OCD in the slightest form it will drive you mad Rolling with laughter
Post #303408 30th Jan 2014 2:04pm
Cheshire110
I've already got 2 mud ones, don't know what you mean about the american way? they seem to work fine for me!
press the top they come on, press the bottom and it goes off Cheers, David
Post #303410 30th Jan 2014 2:10pm
SailingTom
Hi David,
Id of thought it should be fairly simple as when I had my dash out all the wires looked pretty long.
When you've done it would it be ok to post a picture please, as this is something i'm planning to do and like you also don't want to cut into the dash.
Cheers Tom Thumbs Up Defender puma dormobile camper
Post #303418 30th Jan 2014 2:29pm
udderlyoffroad
Carling have done the work for you. Click on the 'fitting instructions' tab on any of the Carling switches on the website and it'll show you the pinouts of the hazard and rear wash wipe. You might need to extend some of the wires, depending on your model.
Matt Real trucks don't have spark plugs
Post #303431 30th Jan 2014 3:11pm
Cheshire110
Perfect, cheers guys! Given me much confidence Smile just need to did a double din facia now...
Tom, won't be for a while but if I do I will put pics up for sure Cheers, David
Post #303432 30th Jan 2014 3:31pm
Yup the american way but as you have two mudstuff ones makes sence to keep the trend
UK ones are the revearse
Post #303434 30th Jan 2014 4:03pm
Cheshire110
Ohh ok I get it, hadn't thought of it like that! Will stick to mud then and just been looking through wiring etc and should be ok, just need to sort a double din facia now Cheers, David
Post #303449 30th Jan 2014 5:59pm
Jurassic Defender
Portugal 2000 Defender 110 2.5 TD HT Coniston Green
https://www.youtube.com/watch?v=SMZhPTJBhQA
Sharing here how I did mine hazard switch conversion to a Carlin switch Thumbs Up
Post #1068561 28th May 2025 2:07am
