Home > 130 > 130 Four seater? => done!
Page 2 of 4 <1234>
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Thanks TJN.
theorangebandit wrote:
Ive been tempted to do this. My thoights were to get the single seat from the bench from a European vehicle. As ive notice the split is on the opposite side. This would utilise an almost oem fit( some hole required) abd certainly retain oem look and use. Also id retain fold flat and forward bench seats to van the back end
I was thinking about getting one from uk, but if I'm correct it's no different. Single seat's on the left, bench on the right.
Post #301915 24th Jan 2014 11:00pm
maar10
Netherlands 2014 Defender 130 Puma 2.2 HCPU Corris Grey
4 times recaro cs example
Post #304557 2nd Feb 2014 10:33pm
tookaphotoof
I'm afraid that's way over my budget. Whistle Wink
Post #304581 2nd Feb 2014 11:34pm
maar10
I can't imagine you will sit nicely in the back. If you found a nice setup for the back please post your picture!
Post #306635 9th Feb 2014 8:08pm
tookaphotoof
Maar, you also have a 130?
In our family we're all skinny and not to tall.
Think, I could make a oem looking bracket which allows the seat to move forward for about 2 centimeters so it can recline a bit more.
Post #306665 9th Feb 2014 8:51pm
maar10
Not yet, it will be delivered in/arround March. So at the time only making my shopping list worse. But looking at it at the moment I think i need a priority list as well Smile I already saw (1) but don't know if it also can place the seat more forward with it (don't know how tiny your family is, else you can not floor it).
(1)
Post #306669 9th Feb 2014 9:01pm
ericvv
Post #306675 9th Feb 2014 9:07pm
tookaphotoof
Eric, I dare you to try that with a 130 in Holland registered as a commercial vehicle. You're probably risking getting some sort of "invoice" from the government. Mr. Green
Post #306680 9th Feb 2014 9:19pm
ericvv
Are there now also specs in Holland which define how long a cab on a utility can be at the max? Shocked
Sounds like Jeroen René Victor Anton Dijsselbloem is watching you. Laughing
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #306695 9th Feb 2014 9:46pm
maar10
We have road tax. Normally it's around 220 euro a month for this car (and because of co2 maybe in future a lot more with our politics needing more money every month). Because the basic version fits our "grijs kenteken" rules we pay 40 euro a month. We also don't pay BPM, if you change something outside the strict rules you will have to pay the BPM (13.000) and a fine. So keeping it as standard as possible is required. That's the same reason a lot of dutch versions make the back removable to still be complient. A normal 110 costs 100.000 overhere, a 130 around 40.000 So back to the seats.
Post #306711 9th Feb 2014 10:18pm
ericvv
Post #306715 9th Feb 2014 10:27pm
tookaphotoof
Apart from the minimum size of the load area you also have a cabin size vs load area thing. Better not trying to mess with it. Wink
A 90 as a family car could be big enough for me of only it wasn't for the fact the road tax and the BPM would be insane. You could buy a Disco4 for less.
Post #306716 9th Feb 2014 10:29pm
ericvv wrote:
You don't need to put the seat more forward in order to be able to recline it... You can extend the cab of a 130 giving rear passengers plenty of reclining and leg space.
http://foleysv.com/parts/cab-extension-kit
That's quite an expensive mod at £3,320 plus VAT:
Found these photos online and wondered if this was a DIY version, seems to be about twice as wide as the Foley's version:
Post #328490 5th May 2014 11:10am
tookaphotoof
Apparently Exmoor now has the black span mondus fabric which would make it suit the front seats a bit more. Will have to see how the brackets are because I think these are for the 110?
A Waeco CFX40 has been ordered and will replace the left rear seat for the time coming, but eventually it will move to the middle when I turn the 130 in a 4 seater.
Also discussed the possibility for an external connector to "Prius" my cool-box when I'm parked in front of the house. Cool
Post #337857 13th Jun 2014 6:43am
tookaphotoof
Brought the car to the shop this week and whilst the they prepared the last bits of the custom seatbase, I removed rear seats and the old seatbase. Rear bolts of the seatbase we're already lose and the screws on the front of the floor were screwed in next to the clips.
IMG_8279.jpg by Tookaphotoof, on Flickr
The new seatbase houses two quick accessible compartments and the middle one can only be opened with screws. The fridge will be mounted on top.
Just as I thought the only thing left were the front seats to be mounted, it turned out the frame of the left seat was almost 5mm smaller?!
Wasn't going to fit, so I went home and the shop solved it for me yesterday.
IMG_8282.jpg by Tookaphotoof, on Flickr
We've tested the seat that did fit. The extra legroom and the seating angle is like heaven, though I still prefer to sit behind the steering wheel myself. Mr. Green
Will post some more photos online when it's completely finished.
Special thanks to Maar10 on this forum for the two front seats! The 130 will look like it left the factory as a four seater now. Thumbs Up
Post #361870 3rd Oct 2014 8:30am
Page 2 of 4 <1234>
