![]() | Home > Maintenance & Modifications > Air box mod and decat |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Great work and a good write up
Interesting thread. Never thought these simple things would have such a large effect. Keep on modding
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 858 ![]() ![]() ![]() |
Good work
the corrugated aluminum pipe that you used has a lot of losses (due to the corrugated) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
How did you squeeze the pipe between the wing and the bulkhead? It is just a 2" gap between them. Puma 110" SW
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
Did ypu measure the outer diameter of the entry pipe of the air box? My trucks in for paint work still! And im trying to compile parts so when I have it back I can get on and fit them straight away. Also need to modify the new Land rover RAI into a snorkel to complete my induction setup
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 ![]() ![]() ![]() |
I'll try to get a pic tomorrow but it slided quite easily,if you remove the original airbox pipework(you have to remove the heater pipework first on a LHD def) and you remove the side grill you'll see plenty of space,you can put your hand inside and pull the hose through. |
![]() ............................................................. Earth first. Other planets later |
A little larger than 101mm and little smaller than 102mm!! I trimmed the inside of the 100mm reducer using a grinding wheel like this ![]() Click image to enlarge and "rebored" to the right size,i was lucky enough it had the right size,i'll measure the wheel tomorrow. But with a dremel or a similar tool and some patience you'll get the right result. Don't forget to make a recess-slot, on the inside perimeter of the reducer,i used a screwdriver which i heated with a blow torch,the airbox inlet has a similar protrusion on the underside. Preferably undo the 3 screws that hold the airbox to the inner fender cause manouvering the reducer down there is little difficult. |
Cheers dude ill measure the pipe I have in mind to use tomorrow. Idealy id like to make it all from nice piece of metal pipong to give a smooth induction ill see what I can locate.
I agree but don't forget that i removed almost 1.5 meters of the original ducting connected with a mantec snorkel like this ![]() Click image to enlarge,not the smoothest rubber hose there as i saw from the inside ![]() ![]() So yes,my stage 1 hose arrangement is a success - for me! Retrurning from work tonight i can confirm that the engine breaths a lot better!! Or i am ultra placebo effected ![]() ![]() |
Placebos are just as good as the real thing lol if I feel no difference I wont have spent much in the process. And at the end ill feel a little better knowing my turbo is breathing better. I was going to fit a similar mantec snorkel but was gifted an un used second hand land rover snorkel
I remind you that my defender is LHD and the thin wall hose i used has 80mm outside diameter and about 77 inside diameter. If you use a smoother but with thicker wall tubing,you'll have to use some ready made bends,don't rush and throw money,first check the "route" from fender grill to over the heater blower motor(on LHD def) and to the filter box. Hopefully next week i'll proceed to stage 2 (tubing-not tuning) ![]() ![]() |
Haha ill take my time over it. I have access to alot of engineering machinery so im sure I can create something my first effort will be spent on making a single plate adaptor for the base of me snorkel, itll have a metal pipe in the centre providing a water tight seal. Mines RHD(normal
