Home > Technical > Curious things in the battery box
Page 1 of 3 123>
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
Can anyone identify what these are for?
On the outside of the battery box, between where the passenger legs would be there is a switch (turns 90 degrees left/right) and also some kind of push fit connector or perhaps its just a neat cable exit hole?
Inside the battery box the back of the switch (with the white back) has two battery type screw/nut connectors.
This looks to me like either a manual switch to switch between batteries? or a security device to quickly disconnect the battery.
I have no idea what the other push fit/cable exit thing might be (the black one) but looks like those are also battery connectors.
I have another connector that disappears off into the transmission tunnel but I'll post that 'what is this?' later
Thanks, Dan.
Post #299985 18th Jan 2014 6:11pm
leeds
Isolation switches.
My guess is that the vehicle has been winched equipped in the past and someone has removed winches and cabling.
Brendan
Post #299989 18th Jan 2014 6:18pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Hi Dan, They are both battery cut out switches. The black one works by inserting a removable red key and then turning it to the on position. Like you suggested they may have at some point been used as a means of disconnecting the battery as a security device or your vehicle has had a winch fitted at some point. Hope this helps! Smile
Post #299990 18th Jan 2014 6:19pm
danridge
Thanks guys. Could I use the white one as a quick battery disconnect?
Post #300014 18th Jan 2014 7:32pm
Leenorthants
Yes that's what they are used for
Post #300026 18th Jan 2014 7:44pm
TJ101
As said,, Battery kill switch, and a winch isolator switch
Get one of the below for the kill switch,
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #300029 18th Jan 2014 7:52pm
danridge
Great Been meaning to do some security with the battery.
Is there any reason why I can't wire the battery to the existing switch (black one, winch isolator) ?
I know it's not as secure as a key but the seat pops of anyway and if it's easy to do I'll use it all the time
If not then the key it is.
For either of them, there a right and wrong way to wire the positive/negative?
Post #300046 18th Jan 2014 8:37pm
dondiddy
Dan, Normally it is the positive lead that is isolated. You need to get a new positive cable with a ring terminal at one end to run from the battery positive to either post on the isolator. Your existing battery cable (the one you have removed from the battery)then needs a ring terminal fitted if it doesn`t already have one and then this cable is fitted to the other terminal on the isolator. It doesn`t matter which way round they go onto the isolator as this is a basic isolator without a feed terminal to supply your radio, clock etc. Although you are working with the positive lead it is good practice to disconnect the negative lead at the same time to avoid the possibility of a short. Hope this helps! Smile
Post #300070 18th Jan 2014 9:08pm
danridge
Cheers Don
So like this (before and after)?
Post #300105 18th Jan 2014 10:41pm
dondiddy
Spot on! Thumbs Up
Post #300114 18th Jan 2014 11:03pm
danridge
Cool thanks! As long as I only use this as a security device and not to kill the engine this will not affect the alternator right?
Coming home:
Pull up, ignition off, keys out, isolate battery, jump out.
Leaving Home:
Jump in, connect battery, keys in and fire her up
Post #300120 18th Jan 2014 11:09pm
dondiddy
Yes , Thats the correct sequence. You should never turn the isolator to the off position when the engine is running as it may damage the alternator. The only issue you may have is that your radio if coded will loose the code and the clock if fitted will loose the correct time. Neutral
Post #300124 18th Jan 2014 11:24pm
danridge
Its an after market stereo with no code so that's ok. I'll have to live with the clock. It was hours out when I bought the truck and I though it was broken but I set the time and its been fine. Must have been out cause of the isolator.
Right - if you haven't had enough already Very Happy here's the other one I couldn't work out. Also fitted to batter box wall but close to the transmission tunnel and I can see where the wiring goes.
Any idea?
Post #300129 18th Jan 2014 11:47pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Not too good with electrickery but could you use a wire from the "in" side of the isolator to the "out" side of the isolator with an in line fuse to give power for clock radio etc but would blow the fuse if attempting to start the car with the isolator in the "off" position.Just a thought. 2005 Td5 90 XS
Steve
Post #300131 18th Jan 2014 11:54pm
leeds
To keep codes in the radio, clock running etc put say a 10 amp fuse across the contacts.
If any attempt is made to start the engine fuse will blow.
Brendan
Post #300132 18th Jan 2014 11:55pm
Page 1 of 3 123>
