![]() | Home > Technical > Curious things in the battery box |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5998 ![]() ![]() |
The easiest way around isolator and powering alarm and radio is to join the two connections of the isolator with a piece of wire with an inline fuse in it. The fuse will allow power through so all items keep their memory, but if someone tries to start the engine fuse will blow, killing the power.
Andy |
danridge Member Since: 28 May 2013 Location: Bath Posts: 438 ![]() ![]() ![]() |
Cheers Andy - what would I search for online for that?
and AMP fuse would do the job? 10A?
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
Something along the lines of this would do. Ebay item no eBay Item No. 400591678378 or do a search for inline fuse holder. You would also need 2 ring terminals to suit the posts on the isolator. 10 amp fuse would be fine as it is only providing a supply to the clock. You would have to make sure that you did not leave the likes of the headlights on when switching the isolator off as a high current draw like that would blow the fuse. Also you would need to remember to switch the isolator on before switching on the ignition as the high draw from the glow plugs would be enough to blow the fuse.
Thank you !
Any size blade fuse would be ok, as none of them would allow enough power to start engine. For the first few weeks of this system carry a few spares until you get used to it
![]() Andy |
Thanks Andy
Is there a big enough fuse that would handle the lights being on but blow if engine start was attempted ? |
I think a 30 amp fuse may be able to handle it, it's possibly a bit trial and error. Just make sure cable is suitable.
Andy |
Dan, remember its not really a big deal if the fuse blows! You will only lose power to the clock/radio so it simply means that you put in a new fuse and reset those items then your good to go! When you turn on the isolator then clock/radio and all other electrics will still work, its only the back up power to clock/radio that is lost when the fuse blows.
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
From my basic knowledge of electrickery watts divided by volts equals amps, so 2x headlights at 60 watts each is 120 watts divide by 12 volts will give a current draw of 10 amps.
Of course there will be other things drawing current as well as the lights,30 amp fuse should be plenty. 2005 Td5 90 XS Steve |
Thanks guys
So a 30A fuse will keep the clock running, deal with lights coming on by accident when isolated is on but will pop if ignition is turned without disabling isolator ? If so then that's what ill go with ![]() |
A 30 amp fuse should be OK if "ignition" is turned on (depending on current draw of fuel pump) but will pop for sure if you try to start the engine. 2005 Td5 90 XS
Steve |
Thanks
![]() How do I tell if the in-line fuse cable up to the job? I've got one here but doesn't have any obvious rating on it. Just suck it and see or it a fire hazard? |
That's perfect then
