![]() | Home > Td5 > Defender Soft Top Interior Lighting Doubt!! |
| sherifsalem Member Since: 02 Jan 2013 Location: Porto Posts: 96
Hi gents,
I have been looking at this instalation that i saw for an interior light AMR3155 for a defender soft top 90 TD5 I would like to install the interior light in my soft top, i have the same plug coming out from the dash board all the way up to the sun shield. Click image to enlarge
Click image to enlarge Has somebody used this plug for interior ligthing? can you tell me which is the +ve & -ve i can use for the simple light. in some other forum they confirmed the following (left wires are the ones to use only): Black = -ve Violet / brown= +ve White /vilot= Alarm from ECU??? this is what it was referred as
Thanx for your opinion Happy Travel www.thegippo.wordpress.com |
| SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1733
Hi there, in terms of the simple power to the light you can indeed as you said use the purple wire and the black one.
Cheers Tom Defender puma dormobile camper |
Thank you Tom for your confirmation i will use the Black for -ve and violet/brown for positive, it is a nice DIY from a Portuugese forum for defender soft tops owners needing interior light.
Apparently from the forum when installed the light reacts to the door opening and closing as well as, i have yet to confirm after i install. If you would like to consult here goes the link: http://landmania.pt/forum/viewtopic.php?f=48&t=10126 Happy Travel www.thegippo.wordpress.com |
That's OK
I only know as have only just changed my puma to soft top and its the same plug. Im not sure it will come on with the door open though, it should and mine does. However I have the other half to the plug on mine with the motion sensor for the alarm aswell. Id of thought your right though, just cant guarantee 100% Cheers Tom Defender puma dormobile camper |
Worked beautifully, i have interior light finally in my soft top from the ceiling, just might change the bulb for a led one.
Thanx Tom i will post some photos.. Happy Travel www.thegippo.wordpress.com |
2mm thickness / 6cm wide
Click image to enlarge Just to inform you that you dont need to hook up the negative wire (Left wire)as you get it when you fix the plate to the body of the landy.....meaning you can only hook up the purple (violet)/Brown wire +ve, it will do. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Happy Travel www.thegippo.wordpress.com |
You can www.thegippo.wordpress.com for further clarification.... Happy Travel
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
Hello Sherif,
I saw this on your blog, why do you cover the hoses in metal foil? Just curious. Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Is that a bit of card I between the light and the bracket? If so isn't that a fire hazard?
Hi Vee Tee,
Well i saw it on another similar instalation and the reason given to me was that most rubber tubing exposed to engine heat will deteriorate with time and this works as a heat reflector & a prolonged protection..... I liked the logic and I am using it for a while with no problems!!! i guess time will tell Che Happy Travel www.thegippo.wordpress.com |
Hi MK, You are right ....that is what i thought to myself so what i did is 2 things: 1 -i put an aluminum paper as an isolation between the paper and light. 2- I changed the standard light bulb to a led (less heat source) as you can see the plugs are well isolated i think it is all secure. Happy Travel www.thegippo.wordpress.com |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
I have two for sale ymk00382
| tfloydian Member Since: 26 Mar 2019 Location: South Yorkshire Posts: 3
Hi dorsetsmith. I need one for a 2005 110 TD5. How much do you want and how can I buy it? Thanks.
two i have are from td5 front only lamp with interior space alarm plug £12 inc p&p payment paypal
| All times are GMT |
