Home > Maintenance & Modifications > How do you charge your battery?
Page 2 of 2 <12
ericvv
K9F wrote:
Due to the fact my Defender gets irregular use I am regularly topping up my battery with a charger which can be irksome. I am thinking of a permanent fit of one of these smaller discreet chargers and an aircraft grade electrical connector on the side of the seat box to connect it to the mains. The positive charging lead could also be wired through a pushbutton illuminated switch to prevent backfeeding the charger when not in use. Connect the unit, push the button and away you go.
http://uk.rs-online.com/web/p/battery-char...4E4F4E4526
Why not install the 12S plug and use the adapter for the C-tek as is offered on the disco3 sister forum. Very easy.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #299677 17th Jan 2014 6:37pm
K9F
I have considered the idea of a Ctek charging through the tow socket, however my vehicle sits outside and apart from the mains connection and the throw of a switch everything would be secure and weatherproof. Well as weatherproof and as secure as the inside of a Defender can get. It could be permanently fitted and connected and just throw the switch periodically to charge.
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #299679 17th Jan 2014 6:41pm
K9F
ZeDefender wrote:
Good idea - and just fit a diode to prevent back-feeding perhaps?
I have given a little more thought to my plan and by feeding the live battery feed from my Blue Sea with a 20 amp fuse I could switch the negative battery feed through a Carling illuminated switch which will prevent backfeeding when switched off. Unlike a diode I'll also have an indication when it's charging.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #299822 18th Jan 2014 8:39am
ZeDefender
Sounds good to me Smile Tell someone you love them today because life is short.
Post #299825 18th Jan 2014 8:53am
dgardel
Italy
Re: How do you charge your battery?
Pickles wrote:
I have a C Tek battery charger which specifically says it can charge with the battery in the car with leads connected etc, and I have the "easy connect" leads to make it easier.
However, reading the Puma's owner's handbook, it says that the battery has to be removed from the vehicle to be charged.
How do you guys charge your Puma's battery should the need arise?
Thanks, Pickles.
And when you are driving?
The battery have a vent pipe so, no problem! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #299826 18th Jan 2014 9:01am
VeeTee
Netherlands
Thumbs Up
That's a good idea, thanks K9F!
I have the CTek in the seatbox, this way I can see when it is connected and it is good to be able to disconnect to prevent backfeeding.
Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #299875 18th Jan 2014 12:02pm
K9F
Thumbs Up
Welcome. A local Chandlery to you may be able to provide the switch quickly and reasonably priced. As stated you could then hardwire the charger and save faffing about.
Thumbs Up
http://www.force4.co.uk/10278/Carling-Swit...-Line.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #299877 18th Jan 2014 12:08pm
VeeTee
Netherlands
K9F, I already have the charger hardwired, together with an inverter, to a marine grade mains connection on the rear of the truck. I also have a spare Carling switch on the Mudstuff Dash console.
So, just need to do the wiring. Wink Cheers, Vincent
MySite
Post #299879 18th Jan 2014 12:17pm
K9F
Thumbs Up Inverter? Now there's a good idea! Could you post a link to the one you've fitted? Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #299885 18th Jan 2014 12:39pm
VeeTee
Netherlands
e-ast CLS 300-12 Sinus-spanningsomvormer 300 W/600 W 12 V= (11 - 15 V) - 230 V/AC inverter
I do not use it much, just for charging phones or laptop if they can not be charged from 12V directly. Cheers, Vincent
MySite
Post #299896 18th Jan 2014 1:14pm
K9F
Decided to go ahead with the fit. The charger I used was this one....
Sits perfectly in the Nakatanenga glovebox. Cut the crocodile clips off and ran the positive through a 20 amp Carling switch back to my Blue Sea fusebox and fitted a 15 amp fuse. The negative I also fed back to the Blue Sea and connected it to the negative bus. Effectively when charging I am 'backfeeding' the battery through the Blue Sea fusebox.
The mains lead I fitted a three pin fixed aerograde small bulkhead electrical receptacle. I also made a short lead with the corresponding electrical connector on and a standard domestic plug.
Ultimately connect an extension lead throw the Carling switch and it's charging. No faffing about lifting the seat etc. The Carling switch and electrical receptacle I fitted in the passenger footwell on the hinged fusebox panel under the dash.
Post #302035 25th Jan 2014 5:11pm
Page 2 of 2 <12
