Home > In Car Electronics > Should the radio work with the ignition off (MY13 Puma)?
Jim_Bean
Should I be able to use the Alpine radio in my MY13 with the ignition off?
I just tried to use it but no joy. I'm sure it did work before with the ignition off by just holding down the on switch for a few seconds.
Post #299562 17th Jan 2014 11:40am
steve E
Wales
Hi Jim
my 08my 90 truck cab comes on with engine off and says on the display 1hour
i assume its so you can have the radio on without draining the battery.
this is a land rover head unit.
Will check the 110 later which has the alpine head on Thumbs Up
steve
Post #299563 17th Jan 2014 11:44am
Jim_Bean
Thanks Steve!
I blew a fuse on the interior lights/radio earlier and i'm sure I could use the radio before I replaced the fuse.
Just wondered if i'd blown anything else!
Post #299564 17th Jan 2014 11:46am
steve E
Wales
Hi Jim
The radio does not work without ignition on with the Alpine head unit.
steve
Post #299648 17th Jan 2014 5:12pm
Jim_Bean
Thanks Steve - just wanted to be sure!
Saved me checking ALL the remaining fuses Thumbs Up
Post #299661 17th Jan 2014 5:36pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
steve E wrote:
Hi Jim
steve
It does. Once you turn off the engine, so long as the key is in position 1 you can use the radio Very Happy
Post #299775 17th Jan 2014 10:57pm
steve E
Wales
On the land rover head unit the key doesn't need to be in and you get an hour before it turns itself off.
I was trying with no key. Thumbs Up
Post #299780 17th Jan 2014 11:04pm
JWL
That has been a common thing with Fords, another legacy of the Americans. They probably offloaded a couple of decades worth of stocks when they left Rolling Eyes
Post #299791 17th Jan 2014 11:54pm
