Home > Maintenance & Modifications > Replacement headlight harness - Highly recommended
Page 1 of 11 123 ... 91011>
ZeDefender
Just thought I'd share this with you all:
I just got round to "properly" fitting a replacement headlight harness taking power directly from the starter battery:
https://shop.landreiziger.nl/lichtversterk...elaar.html
I know the site is in Dutch but it's just a case of a few plugs, cable to the battery and earth to the body - making your own would also be simple but I'm lazy Smile
Apart from relieving the headlight switch (no more melting), it has also eliminated flickering with my LED lights when parked/starting etc. (due to undervoltage).
I measured the voltage at the headlight connectors (LEDs connected) with the standard harness and with the replacement.
Although the Scangauge (ECU) said 11.8V with engine off, the voltage at the lights (standard) was only 11.1V! With the new harness it's...11.8V Mr. Green
Bearing in mind these are LED lights with low current draw, think what a difference that could make with Halogens Shocked
It's a dead easy conversion and now on my list of essential Defender upgrades. I'm sure there are loads of other kits out there - mine was p!ss easy to install (1 hour tops). I might take some pics with a "how to" if anyone is interested (but only when this Censored miserable weather clears up...
Thumbs Up Matt Tell someone you love them today because life is short.
Post #299535 17th Jan 2014 10:21am
I had a similar loom on my old 90, from ARB.. make the lights much "whiter" instead of yellow.
With a few relays and some cable they're easy to knock up.
Post #299579 17th Jan 2014 12:27pm
geobloke
I remember being highly jealous of a friend of mine, he had a Series IIa with four headlights. all of which were wired through relays from the battery. The light that came off them was just phenomenal and they were sealed beam units too. The light that came off of my defenders H4 headlights was decidedly pathetic in comparison...
I think the guys "down under" do this mod a lot due to the melting light switch. Which I have just had to replace...
Post #299598 17th Jan 2014 2:05pm
ericvv
Post #299608 17th Jan 2014 2:26pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
http://www.defender2.net/forum/topic25376.html
look here for my guide on how to do it all yourself. No real need for a kit imo.
Post #299612 17th Jan 2014 2:36pm
ZeDefender
ericvv wrote:
Matt, any possibility for you to give more detail of the installation, maybe a step by step how to.....?
Rgds, Eric
Sure thing Smile
Bear in mind this is for LHD. I think just mirroring it would work for RHDs.
1) Locate a position for the relay assembly and earthing point:
I just used an existing wing-bolt for earth (I know it works as I used it for the HeatShot). I set a rivnut into an existing hole nextdoor to mount the relay assembly:
Using the Landreiziger harness and Speaker 8700s (they have some cable length themselves), this position was exactly right for everything to reach. However, for standard lights with bulbs the assembly should be further forward (about a foot) - make sure to check!
2) Extend the live cable to reach the battery (the instructions say use the alternator but this isn't practical on the Puma. For example, here's how I routed mine (next to the HeatShot). Ignore the big coil of red wire - I mean the ones going down:
It enters the battery box through the same rubber grommet as the earth cable and screws onto the positive terminal:
3) Remove both headlamps so you can get at the connectors.
4) From the harness relays come three cables - two short and the other long. Feed the short ones into the cavity behind the headlamp on the relay side. Simply disconnect the headlamp and reconnect it to the (power) socket at the end of one short cable and connect the original plug to the relays via the socket on the other short cable. You can see one of the cable connectors sitting far left:
5) The long cable goes under the fan, across, and up:
and into the headlamp cavity on the other side:
Simple reconnect the lamp to the harness socket and leave the original socket free.
6) Re-fit the lights, make sure none of the cables chafe and off you go.
Sorry not everything is photographed but I just aligned the lights and don't want to disturb them. It was pretty self-evident where to route the cables and there is plenty of space to get behind the lights. Also there are plenty of existing pipe/cable mountings etc. to attach them to and keep them tidy.
To be honest, it's one of the jobs I've put off the longest but one of the easiest I've done Thumbs Up
Cheers,
Matt
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #299633 17th Jan 2014 4:18pm
LR90XS2011
thanks for that I have a kit to fit just waiting for a dry day DEFENDER 90 TDCI XS,
Post #299668 17th Jan 2014 6:13pm
geobloke
where did you get yours from?
Post #299712 17th Jan 2014 7:57pm
ericvv
Post #299713 17th Jan 2014 8:00pm
ZeDefender
I got the one from the dutch link above:
I know you can DIY it cheaper but it's nicely made (all connectors are high-quality) and sufficiently idiot-proof for me. Instructions are not necessary.
Also the guys there speak English Thumbs Up Tell someone you love them today because life is short.
Post #299722 17th Jan 2014 8:38pm
LR90XS2011
ditto DEFENDER 90 TDCI XS,
Post #299728 17th Jan 2014 8:51pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
+1 Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #299770 17th Jan 2014 10:50pm
NoDo$h
Yup, fitted the same kit, definitely recommended.
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #299787 17th Jan 2014 11:35pm
bob neville
Does anybody in the UK sell the landreiziger harness or is best to get directly from Holland ?
2013 Defender 90 CSW - sold
Post #299889 18th Jan 2014 12:55pm
WelshGas
Getting it from Holland was quick and painless. Couldn't find anyone in the UK, but that was about 18mths ago. I think they originally came from a Swedish maker, but they don't sell on-line. Thumbs Up LANDYWATCH
Post #299913 18th Jan 2014 2:12pm
