![]() | Home > Maintenance & Modifications > Added second interior light to my DCPU |
| DingoDad Member Since: 02 Jan 2014 Location: Norwich Posts: 20
Love LED's . May I ask where you found them? 94 Defender 110 Wagon
2012 Mini Countryman SD (Work Car) |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
It amazes me that to this day LR still don't put an interior light over the 2nd row of seats either in a double cab or station wagon. I soon did this after buying my SW and is one of the best things I ever did, now with leds fitted it is just spot on. It's not a mod that costs a great deal of money, just another interior light fitting, I used a bit of ply to help fix it in place and your time.
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058
That's been on my "to do" list for over 4 years now!
| rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548
Dingo, the LEDs are from eBay, they are dead cheap jobbies from Hong Kong. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
You can be lucky with the el-cheapo ones off fleabay, mine have been in 4 years now
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Where are the 'Doom Mongerers?'
Nice job Russ, thanks for the info about the lights Wipac may be the way forward for me especially with the COR 4 light guards I need same size/shape as OEM. Treat every day as if it is your last....one day you will be right!! |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Does this cause any problems with the AS10?
Merlin |
Nope, none at all
| appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630
I'm a little behind on this, but how did you actually fix it above the headlining? Just about to do the same to mine.
I used a standard Defender courtesy light that fixes to the headlining. A metal bracket sits one side of the headlining and the light unit bolts to it effectively sandwiching the headlining. 2015 90 XS CSW TDCi - Beautiful
| Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340
I'm doing this at the same time as the Terrafirma roof console
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060
That's my plan. But need to find roof console first
Andy |
| Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223
Need some help please form someone who has added a second row light!!!
I had the headlining down to add int he sound proofing last weekend and decided to add a second row light into the 110 SW. So I have taken three wires from the cables on the rear light by splicing into them with crimps, then running the cables through the headlining and out of a hole I have cut in the headlining above the second row seats.... I haven't connected the second row lights up yet but the front light and the rear light now don't operate with the door opening but are either on or off only? I am also trying to add a light to the vanity mirror for the better half but not surge where to take this feed from now? Please could someone help me to understand: 1 - Have I done the right thing in taking the feeds directly form the three wires on the rear light? 2 - Where can I get the feed for the vanity mirror from? Thought this would be really simple... Thanks in advance fro any help!!! James |
I can't remember exactly how I wired up the 2nd row light but I'll have a look when I get home and let you know
| All times are GMT |
