|  | Home > Maintenance & Modifications > Added second interior light to my DCPU |
| DingoDad Member Since: 02 Jan 2014 Location: Norwich Posts: 20      | Love LED's . May I ask where you found them? 94 Defender 110 Wagon
 2012 Mini Countryman SD (Work Car) | ||
|  12th Jan 2014 6:40pm |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443      | It amazes me that to this day LR still don't put an interior light over the 2nd row of seats either in a double cab or station wagon. I soon did this after buying my SW and is one of the best things I ever did, now with leds fitted it is just spot on. It's not a mod that costs a great deal of money, just another interior light fitting, I used a bit of ply to help fix it in place and your time. | ||
|  12th Jan 2014 8:12pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      | That's been on my "to do" list for over 4 years now! | ||
|  12th Jan 2014 11:16pm |
| rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548      | Dingo, the LEDs are from eBay, they are dead cheap jobbies from Hong Kong. 2015 90 XS CSW TDCi - Beautiful
 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome | ||
|  13th Jan 2014 8:18am |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443      | You can be lucky with the el-cheapo ones off fleabay, mine have been in 4 years now   | ||
|  13th Jan 2014 10:40am |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Where are the 'Doom Mongerers?'     Nice job Russ, thanks for the info about the lights Wipac may be the way forward for me especially with the COR 4 light guards I need same size/shape as OEM.  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  13th Jan 2014 10:44am |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982    | Does this cause any problems with the AS10?
 Merlin | ||
|  15th Jan 2014 11:26am |
| rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548      | Nope, none at all    2015 90 XS CSW TDCi - Beautiful 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome | ||
|  15th Jan 2014 11:43am |
| appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630      | I'm a little behind on this, but how did you actually fix it above the headlining? Just about to do the same to mine. | ||
|  29th Mar 2014 8:17am |
| rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548      | I used a standard Defender courtesy light that fixes to the headlining. A metal bracket sits one side of the headlining and the light unit bolts to it effectively sandwiching the headlining. 2015 90 XS CSW TDCi - Beautiful
|  29th Mar 2014 10:19am |
| Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340      | I'm doing this at the same time as the Terrafirma roof console    | ||
|  29th Mar 2014 11:40am |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060    | That's my plan. But need to find roof console first    Andy | ||
|  29th Mar 2014 12:29pm |
| Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223    | Need some help please form someone who has added a second row light!!!
 I had the headlining down to add int he sound proofing last weekend and decided to add a second row light into the 110 SW. So I have taken three wires from the cables on the rear light by splicing into them with crimps, then running the cables through the headlining and out of a hole I have cut in the headlining above the second row seats.... I haven't connected the second row lights up yet but the front light and the rear light now don't operate with the door opening but are either on or off only? I am also trying to add a light to the vanity mirror for the better half but not surge where to take this feed from now? Please could someone help me to understand: 1 - Have I done the right thing in taking the feeds directly form the three wires on the rear light? 2 - Where can I get the feed for the vanity mirror from? Thought this would be really simple...   Thanks in advance fro any help!!! James | ||
|  17th Jun 2014 5:12pm |
| rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548      | I can't remember exactly how I wired up the 2nd row light but I'll have a look when I get home and let you know    2015 90 XS CSW TDCi - Beautiful 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome | ||
|  17th Jun 2014 5:40pm |
| Posting Rules
