![]() | Home > Maintenance & Modifications > Air box mod and decat |
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
That's the picture I seen |
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Haha dont feel ashamed I too did not locate the nakantnenga kit.
I have noticed the beauty of the short distance between the wing top and the air box. Means that theres evwn less risk of adding a restriction. Ill certainly need a second snoe cowl. Infortunately I want an ex mod metal one to match the one im soon to fit on the heater induction side |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Pete, mine have not the ABS and it is LHD! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
dgardel, could you please get me some under bonnet pictures of the LHD standard intake ?
Pete,
I'm in Kuwait until January 23. When I return I will be happy to make you photos, can you wait? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
No problem, ill see if i can get some in the mean time,. if not it can wait.
pete |
meanwhile
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
first pics of my engine
| fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126
The intake is the same but unfortunatly much space is occupied by the heater air intake,the hose from the fender grill to filter box has to be very flexible to go under the heater intake Please do your best,i can't wait for another(decent) filter box! |
Just took some pics of the LHD setup..
And one from underside.. ![]() |
Thank you for the pictures, that does look tight on the LHD
Pete |
| william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259
But surely there will still be more space than a RHD non ABS motor as they fit the webasto heaters in there.
Fair enough they have to take the wing off to install it |
| tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436
this is what i have done as posted earlier
http://www.defender2.net/forum/topic17821.html |
Since i already have a mantec snorkel (metal tube one,attached to the roll cage),i'll follow your solution,otherwise i would use the top wing grill for air intake and an old style snorkel(from top of the wing) and would use the side grill for heater..
