| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045
^ +1 1999 Defender TD5 110
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Back to the thread. So today, having some spare time I looked in to why one of my spotlights has been working a little independently, turned out that the earth tab on the bulb holder had snapped off. I tried to solder a wire with a suitable connector onto the bulb holder but as it was made of die-cast muck it wouldn't stick so a bodge job was required. Just stripped off about an inch of insulation and threaded it around the wire retainer that holds the bulb in, bit of solder to keep the wires all together, sorted. The other spotlight on the A bar dismantled to empty the last of the Salisbury Plain puddle water, well when the water was lapping on the bulkhead there has to be some consequences. The air filter had a wet spot in it, I only have a raised air intake and never did intend to use it as a snorkel.
Still had some time left so I decided to put my newer winch cable on, my old one, whilst not ever been overworked is over 6 years old and is not looking very pretty, becoming very rusty. I pulled the old one off, disconnected the fixing to the drum, got the other one and fixed the end in place. Then the fun bit, dragged it out up the street in a straight a line as possible inbetween the parked cars. Look round to see if any neighbours about, before I trip them up or drive their motor on the cable. Right now winch in, all going well keeping some tension on, I'll respool it when I get the chance and space later, all of a sudden there was a snag winching in, as it came down the street the hook had snagged on a gully cover and flipped it open, the trouble with using wireless winch controllers is the delay in response of the winch, for more control I use the corded handset but the wireless one is less bulky. All got sorted, drain covers returned to position, no granny's dragged kicking and creaking down the street so a succesful outcome, much nicer when the sun is out as well. |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Trundled down to Yeovil to drop off the black hannibal, took the back roads due to the flooding.
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Still sunny and mild here, but next week will turn colder so the early morning salting brigades will come back in full force.
So today cleaned it (=car wash Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| Criffel Member Since: 14 Dec 2013 Location: Dumfries Posts: 42
Entered my first TYRO and didnt come last!
2007 Discovery Rimini Red. Gone. Thanks for the memories. 1994 Defender 90 300 TDI - Galv chassis No one warned me Land Rover are not cars but an obsession! |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Checked the water leak work from yesterday and..........
It still leaks |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785
Spent the weekend using the interior space to the max!
It's great to have cavernous space when transporting stuff 2011MY 110 XS USW Black |
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265
Towed my boat 220 Miles from Wales
| v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 455
Emptied about an inch of water out of the passenger footwell - again.
| DingoDad Member Since: 02 Jan 2014 Location: Norwich Posts: 20
Surprised you couldnt sail it from Wales with all that lovely weather! 94 Defender 110 Wagon 2012 Mini Countryman SD (Work Car) |
Fixed the water leak on the third try. Touch wood
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2279
There wouldnt be any leaks ,,,, if it Was made of wood
| Kev stephenson Member Since: 27 Feb 2012 Location: Huddersfield Posts: 56
You haven't fixed it, it just didn't rain today. 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys 1996 130 300TDi chip truck for tree surgery business |
| All times are GMT |
