![]() | Home > Maintenance & Modifications > Air box mod and decat |
MINE!!! Pete ONE FOR ME! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Would this stuff do the job?
http://www.autosiliconehoses.com/silicone-...etres.html |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Yes that sort of pipe Borderterrier.
When I did the one I made as a prototype test wing backing it was from some alloy I had kicking arround to attach the pipe to. As Ian has pointed out, this is fine on non ABS cars but the ABS cars are a little tight for space. Its also very tight next to the alternator bolts on both abs and non abs cars. ![]() Click image to enlarge ![]() Click image to enlarge Pete Last edited by bell-auto-services on 12th Jan 2014 12:56pm. Edited 2 times in total |
Very next. Pete. I was thinking of using the heater intake on the top of the wing though.
Depending on the speed you are wanting to do something im already working on a solution that is an easer fit but it will be some time yet before ready.
The pipe I made above worked very good albiet a bit crude and for sure helped with breathing which lead me to the next project, Injection moulding a pipe from the wing to the air box for ease of fitment, and a new air box that has no restriction inside all as a bolt on fit. These pictures show our unmodifyed drawings we had 3D lazer scanned which will aid us to adjust the restricted areas and have made less restrictive. ![]() Click image to enlarge ![]() Click image to enlarge Pete |
I think Nakatanaga do something like this as a kit, Ive not seen in in the flesh but have seen pictures. It uses both the side and top vents I beleive. If you do make one your self to add extra air in combined with the side vent do be aware of the wing top getting water in it though, IRB do a snow vent that may help protect against this problem ?? Pete |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
Not a bad ofea to plum in the top and side vent. Im going to spend some time locating the kit that maybalready exist
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 891 ![]() ![]() ![]() |
Well, 45 mins with a Dremel this morning and i had this
![]() ![]() Click image to enlarge |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21018 ![]() ![]() |
Can you not just take out the water separator thing then? If you can't it's not so easy then..
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Steve, do you mean the "fan like" thing? Yes you can but mine did not want to let go and had to be forcibly removed
Mine was a PITA to remove too.
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707 ![]() ![]() ![]() |
Will this not do for the wing top air intake?
http://nakatanenga-tours.de/shop/article_O...DOAITD4%26 2008 Defender 110 XS SW - M57N2 / 8HP70X |
I suppose it would, but it's expensive. I am going to go for silicon hose 102mm dia and a home made link to the wing top bent. I shall add a snow cowl and bobs your uncle - maybe!
Wow! I really have no idea wherw people pluck their prices from! Ill be making my own version using all the same materials as Mr borderterrior. Unless I manage to hide in the metal bay at work enough I may be able to make up an nice top spec welded metal intake
