Home > Td5 > Doing injector seals a service item ?
df1
From reading the posts it seems a common issue to have injectors leaking.
Do owners change these as a service item or just wait till the problem arises ?
I prefer to keep on top of preventative maintenance but not throw money away.
Replaced the fuel pump a few months ago even though original was working fine but has done 100k miles so I reckon it's due for retirement !
Should I consider the same with injector seals/washers ?
Post #296424 6th Jan 2014 8:56pm
It's not a service item, but wouldn't hurt to do it.
Easy enough job. although a slide hammer with a "hook" on it helps to get the injectors out
A little dab of grease to hold the washer in place. some oil/lubricant to help the seal go "in" easily.
and make sure you fit the injectors back in the order they came out, unless you want to reprogram your ECU.
The injector lash is dead easy to adjust too.
Post #296433 6th Jan 2014 9:15pm
df1
Is it just the few seals, washers and cover gasket I need then ( fitted a new loom couple of years ago so should be grand)
Suppose around service time would be better n renew oil etc at same time.
Post #296446 6th Jan 2014 9:50pm
Yes, 5x seals, 5x copper washers,
I never bother to renew the rocker gasket, I just put a thin line of instant gasket all around it, never had one leak yet.
Post #296456 6th Jan 2014 10:08pm
df1
Cheers, job for weekend.
Post #296508 7th Jan 2014 7:17am
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
A long Allen key under the bridge between the injector halves as a lever works very well too.
Post #296509 7th Jan 2014 7:51am
Ruari
2000 Defender 110 Td5 HT Alpine White
Workshop manual says to replace the 6 x rocker arm bolts and the 10 x lash adjusters.
Who does that?
Post #296535 7th Jan 2014 11:25am
psimpson7
I tend to change the bolts, and have had issues with the lash adjusters before on a late td5 engine, so nowadays would change them aswell by default. (if I had the head off - the lash adjusters cannot be removed when just doing injector seals)
Post #296539 7th Jan 2014 11:48am
Ruari
Do you know the part numbers for bolts and lash adjusters?
Post #296574 7th Jan 2014 4:42pm
psimpson7
Post #296713 7th Jan 2014 10:28pm
Podrob
Couple of tips. If you put insulation tape over the grove in the injector it helps prevent the seal twisting when you fit it.
When turning the engine over to adjust the injector rockers it is easier to jack up one front wheel and turn it than remove the fan and put a socket on the crank bolt.
Post #297048 8th Jan 2014 10:27pm
Laurie
Only use genuine seals bought from a franchised dealer.
There are many adverts out there (especially Ebay) which sell fakes as genuine.
They don't work. You'll be doing the job again in two weeks.
Post #297054 8th Jan 2014 10:33pm
Podrob
I never went near the lash adjusters when I did mine but I did replace the injector rocker arm bolts along with the injector adjustment screws and lock nuts.
Post #297065 8th Jan 2014 10:45pm
