![]() | Home > Technical > Wipers stopped again |
| Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670
There is 2 little gearboxes in the dash that drive a spindle through the bulkhead and onto the wiper arm. Ive seen a few times when the spindle has ceased and then the fuse blows for the motor. Check your fuses first and if they its blown and then blows again then it will probably be the spindles. Cheap part to buy but the whole dash needs to come out to fit them.
Pete. |
| Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335
you don't define what 'stopped completely' is - nothing at all, wipe partly then stop across screen, etc?
But does sound like the motor was not needing replacement. |
