![]() | Home > Puma (Tdci) > Raised air intakes |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
I'd go Safari if I was going to at all, and yes you can indeed rotate the head as far as I am aware.
A good seal on them too as they are a Snorkel and not a RAI like the Mantec. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Andy, I have used Safari snorkels with no problems what so ever.
Yes you can rotate the head but never really felt the need too. You can get a pre cleaner for the safari snorkel. However if you have a light bar/roof rack that might impede on the fitting of it. If that is the case the Aussies have a sock which fits inside the main tube. Brendan |
I've got a factory one on my TD5. Very pleased with that.
Tackles bonnet depths without any problem. (More than I can say for the door seals ![]() ![]() |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
Be careful what you get. Most are only RAI and rely on the seal to the wing. The seal inside the wing from the factory is not always err sealed.
On my TD5 the Safari / Puma Snorkels are RAI but if you use the 300tdi version it's a proper Snorkel. It does not rely on the seal to the wing but is fully moulded with a connection for a hose direct to the filter housing. I do not know if the 300tdi will fit your Puma but a look on the Safari web sites specification pages will tell you. It did fit my TD5 easily and no modification is necessary. ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
Fitting the earlier one is no go for a Tdci as air box is in a completely different place, it's now by the off side headlight.
Andy |
In that case check out the Snorkel for the V8. Same install on the wing but longer connecting pipe to the air box. Might work
http://www.safarisnorkel.com/snorkel/ss525hf/ss525hf.htm 2007 TD5 90 Hard Top |
ozrob Member Since: 31 Dec 2013 Location: Snowy Mountains Posts: 8 ![]() ![]() ![]() |
Any updates as I too am looking at getting a proper snorkel, the Safari SS580HF which is recomended for the Puma is only a RAI.
I have a 2013 Puma 2.2. |
4wheeler Member Since: 13 Apr 2010 Location: Melbourne Posts: 87 ![]() ![]() ![]() |
I had a Safari Snorkel fitted to my 07 Defender. Although the original pipework from the air filter box to the wing side intake seemed to be retained, the installer properly sealed all connections including the duckbill drain of the air filter box. Good quality workmanship should mean that it is watertight. I have had Safari snorkels fitted to almost all my 4x4's and although connecting pipework might differ from vehicle to vehicle, all connections have been sealed with good quality sealants. The only time a vehicle has ingested water, the 4x4 did not have a snorkel/RAI fitted. Luckily it was a petrol engine, but I ended up cracking the head. I avoid deep water where I can. Been there, done that.
If fitted properly I would not think there should be an issue. To be honest I was more worried about the under-seat box electrics flooding, water pouring through the door gaps and water entering the floor gaps than the Safari snorkel causing problems. ![]() |
In the end I brought the safari SS580HF, which retains all the original pipe work. I did this for a couple of reasons, the V8 one that comes with a length of pipe is £300 (nearly £100 more), I could not find what size the pipe is, so don't know if compatible. Also the SS580HF is high flow, so won't restrict the air supply as much as the other models. I have the advantage of being very good with sealer as a bathroom fitter, and have managed to seal my old mantec plastic jobby on the Td5 so am confident this will be easy enough.
The ideal situation would be to get hold of a V8 snork and compare with Tdci system and see if it can be made to fit, but not sure it would due to position of abs unit. Andy |
