Home > Maintenance & Modifications > Cargo Barrier / Dog Guard |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 |
Muddy feet got mine, I think I payed L/R prices-will know when final bill comes.
Try Team Valley Landrover. The independant place they are cheaper than the main dealers. Oh and see you on the 9th 59 2.4 110 XS Utility 55 TD5 110 CSW Special Vehicle |
23rd Mar 2010 2:43pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I got mine from Duckworths. Cheaper than buying it from my local dealer. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
23rd Mar 2010 3:30pm |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 510 |
Does anyone have one fitted to a 90, if so does it restrict the passengers in the back at all with legroom etc, some pic's of one would be great, the guard that is not the passengers Cogito ergo sum
23rd Mar 2010 5:23pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Try TLO on the Disco3 Site he offers an eeeeeeeeeeeeenormous discount to forum users on genuine Land Rover gear Original Member Pie n Pea Club.
110 HCPU Tipper |
23rd Mar 2010 9:16pm |
In the 110 it definitely restricts the rear passengers. I'm pretty short but I'd not want to ride in it for anything longer than 15 mins. You'll be slightly better off in a 90 (with the longer load bay) but my guess from memory is that you lose around 4" One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
23rd Mar 2010 11:02pm |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
this was mine fitted in the 90,
has anyone fitted the 90 rack into the 110, is it just a matter of a new bracket system. not fussed that it has no trap draw in the bottom guard... if not, then this one likley for sale... |
23rd Mar 2010 11:33pm |
If you can figure out a new set of brackets then I would imagine it would fit... maybe.
However, all of the attaching brackets (and there are quite a few) are going to be different. I also wonder whether it sits in a different place. The one in the 110 nestles into the window recesses (on a CSW). If you don't have that trim then I guess it just butts up against the sides but I suspect you'll end up mucking about for ages, getting frustrated and then buying a definite 110 model (and then spend ages mucking about trying to get that one to fit!). One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
24th Mar 2010 12:00am |
chopdogs Member Since: 10 Mar 2010 Location: Wiltshire Posts: 108 |
Have you considered getting a dog harness and attaching it to one of the rear seatbelts?
Cheaper and less fiddly to fit than a guard. It's what I did until our hound got out of the chewing phase |
24th Mar 2010 8:03pm |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 |
Oh, and the genuine article does not fit without some butchery of the brackets!
Rather dissapointed to find that I fitted the brackets on my 110, measured the distance between and this was 10mm smaller than the width of the guard. So be prepared to elongate the holes in the fixing brackets! |
25th Mar 2010 4:42pm |
Thanks for the replies, guys Cogito ergo sum
25th Mar 2010 8:35pm |
Chunk Member Since: 19 Oct 2009 Location: County Durham Posts: 154 |
Fitted gen-u-wine dog guard tonight after work, took about 2 hours all told.
Went on great, after reading the faff some of you have had I was pleasantly surprised - and no damage to myself! Thanks to The Large One on the Disco3 forum for sorting me out with a tidy discount, and Willy for the tip. |
7th Apr 2010 7:20pm |
Nice one
Just be careful you don't thread or round off those crappy little Allen bolts at the base If I were you, I'd just replace them straight away with proper high strength steel bolts (you can stick with the captive nuts). You'll then be able to use a proper spanner rather than a soft Allen key Trust me - the alternative is very frustrating One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
7th Apr 2010 10:32pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
I got a guard built in to the deal on my Puma 90 and they tried to fit the guard from a TD5 90 and it would only fit if the window surround mouldings were removed. I went ballistic when i went to pick up a brand new Defender with metal sides exposed and the TD5 guard in place... I rejected the car untill correct Puma guard was sent and fitted and even then all the poppers were not replaced. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
8th Apr 2010 11:16pm |
