Home > Puma (Tdci) > 2007 Defender Blower Switch
Page 2 of 2 <12
Dash is easy! Took me 10 mins to get the heater controls out last night. My trick is to unscrew the two screws, pop the panel out, disconnect the socket ("cigar lightet") only (leave radio in situ) then hang the bottom of the panel on a string from the roof console (rear view mirror would probably work too, but I no longer have one). That way no wiring is disturbed, very little needs disconnecting, and the radio doesn't need resetting.
I'm not sure if this would work with the factory head unit - there may not be enough slack.
Post #292739 23rd Dec 2013 4:40pm
T1G UP
anyone ever sorted this with find a linear potentiometer to swap for the 3 point switch?
OR
can a resistor be put in line to tone all 3 setting down by say 50%
Post #412212 29th Mar 2015 10:36pm
Page 2 of 2 <12
