![]() | Home > For Sale & Wanted > [For Sale] Free Defender Rear Quarterlight Windows and Seals |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
£10 Posted
Free just pay the shipping
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2681 ![]() ![]() ![]() |
So...I have got a Utility Station Wagon with no quarterlights. Are these fairly easy to fit? I like the idea of a bit more rear-view vision (and a bit more light in the back)...
Anyone done this can offer advice ![]() Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Easy enough you just need to take time to mark well up before cutting. Also don't make the cutout to big or the window can be pushed through or if you make it too small it's hard to get the rubber trim strip in.
As with most things do a google and a fitting guide will appear ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
Use masking tape over all areas you intend to cut, then you can draw reference points and all your dimensions on it. The measure and measure again and again lol then cut. It'll also prevent damage to surrounding areas with any tools I.e. When you go to cut it and also stop your drill bit worming it's way around before drills through for your pilot hole for the blade.
Don't forget also if you cut it slightly too small you can adjust it, too large and you've had it. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
