Home > For Sale & Wanted > [For Sale] Free Defender Rear Quarterlight Windows and Seals
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
A pair of Defender Rear Quarterlight Windows and Seals.
Used Standard glass and seals.
Just pay the postage (£10) or collect them from South Bucks.
I'll bin them in the New year Shocked
Post #285376 26th Nov 2013 3:12pm
epictrail
£10 Posted Question
Post #287892 5th Dec 2013 12:29pm
epictrail
Free just pay the shipping
Post #292013 20th Dec 2013 7:41pm
MartinK
So...I have got a Utility Station Wagon with no quarterlights. Are these fairly easy to fit? I like the idea of a bit more rear-view vision (and a bit more light in the back)...
Anyone done this can offer advice Question
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #292268 21st Dec 2013 7:28pm
epictrail
Easy enough you just need to take time to mark well up before cutting. Also don't make the cutout to big or the window can be pushed through or if you make it too small it's hard to get the rubber trim strip in.
As with most things do a google and a fitting guide will appear Thumbs Up
Post #292290 21st Dec 2013 8:07pm
Use masking tape over all areas you intend to cut, then you can draw reference points and all your dimensions on it. The measure and measure again and again lol then cut. It'll also prevent damage to surrounding areas with any tools I.e. When you go to cut it and also stop your drill bit worming it's way around before drills through for your pilot hole for the blade.
Don't forget also if you cut it slightly too small you can adjust it, too large and you've had it.
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #292348 21st Dec 2013 11:13pm
