![]() | Home > For Sale & Wanted > [Wanted] Puma Rear Cargo Seats Wanted |
| Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756
Are you only after some occasional fold up side faces seats (probably still OK to use in New Zealand?) or the proper forward facing ones that take up most of the rear load area?
If the first then Gwyn Lewis is developing a set of brackets to allow the fitting of Discovery 1 dickie seats in a Puma Defender. Not sure if you can see pics on Facebook.... (pics 33-42) https://www.facebook.com/media/set/?set=a....amp;type=1 |
| HMARR Member Since: 04 Jun 2013 Location: New Zealand Posts: 56 |
Thanks for all your help - I really like the idea of the middle facing ones, might get away with those, but would need to take them out for vehicle inspections (Warrant of Fitness in NZ!)
Does anyone they will ruin the look of my puma? Somebody suggested I would be 'butchering' the car if I did that...? I do have the little step-out in the wheel arches, so hoping the normal forward facing ones will go in ok. Are they easy enough to install or is this gong to be a real shag-around? Hamish |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I'm pretty sure you've got an answer to that one in your other thread: http://www.defender2.net/forum/post290718.html#290718 Darren
