Home > Puma (Tdci) > Puma 5 Seater - want to add the two rear folding seats
HMARR
Hi there,
I have a 2010 110 that came out as a 5 seater. Can I assume that if I buy two forward facing rear seats and the seat belts etc, they will all just bolt straight in? I noticed that the rear seatbelt pillar molds have the 'indent' for the seatbelt straps to come through, but they are not cut out...
Can anyone shed some light on this?
Hamish
Post #290718 16th Dec 2013 12:47am
Likeomg
it might be that simple, it might not it depends on the shape of the rear tub,
if you scroll down on page 16 of this thread by mcma
http://www.defender2.net/forum/topic15681-225.html
you see he actually cuts the rear arches to make the seats fit, ive bought some puma rear seats and planning to do the same thing in the new year
Post #290721 16th Dec 2013 1:23am
HMARR
That looks like a lot of work! Are you sure that is the same for a 110 ? I havn't lifted the boot carpet and looked for bolt holes yet... I assume that is what I am looking for?
Post #290729 16th Dec 2013 2:28am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
You are basically looking to see if you wheel arches are just square or whether they already have the extra step in them as per the photos in the other thread.
If you don't have the extra step then you have 2 options, first you can cut the arches and fit genuine land rover seats or you could look at the Exmor Trim lock and fold seats which fit standard arches.
Post #290737 16th Dec 2013 8:03am
Mcma's conversion was from a van with flat-topped rear wheel arches, whereas your station wagon should already have the recessed arches designed to accomodate the newer forward facing seats. The only issue should be whether yours has the various bolt holes and brackets fitted for the seats to mount on to. I'd suggest taking a look underneath and under the carpet to see what's there. Darren
Post #290738 16th Dec 2013 8:04am
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
it is easy for tdci 110SW.
Bolts that need to screw seats are ''stuck'' underneath the floor. (it is easy to see them)
so you first carefully drill the floor underneath the floor with a smaller ''nose''
and then
drill with bigger drill over the floor so you won't hurt inside of bolt.
for seat belts you have to cut the interior.
good luck Thumbs Up www.newfoundland.gr
Post #290740 16th Dec 2013 8:37am
Porny
Site Sponsor
110's are quite easy...
Unlike a 90 a 110 has the correct floor shape - and also has all of the captive mounts in place. However, you need to drill the floor to get to them. The mounting plate is wheel side of the wheel arch.
This is easily done with a M8 drill guide.
You need the seats and all the fittings, the correct carpets (or cut to suit) and then seat belts and mounts. The grey trims can be easily cut for the seatbelt.
I have done a couple of Utility to CSW conversions...
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #290741 16th Dec 2013 8:39am
