Page 601 of 1394 <123 ... 600601602 ... 139213931394>
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Drove home in the dark for an hour, dipped and main beam failed just as I got home...
Quick inspection with the multimeter and surprise surprise, it's the small knob that's let her down, again Mad
Post #286869 1st Dec 2013 8:47pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Time to fit relays! Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #286948 1st Dec 2013 11:00pm
mrd1990
Top of my to-do list! - Is there a relay kit available to buy online for 2000 TD5s?
For now it's 'mend and make do' until I can find somewhere that sells a high amp toggle switch this afternoon Sheep
Post #287028 2nd Dec 2013 1:02pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
should have used a dimmer switch.... Idea Putting Dreams on Drives at JLR Solihull..
Post #287033 2nd Dec 2013 2:21pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
You don't need a kit - just go to polevolt and buy enough cable and a couple of relays and headlight connectors.
Then just spend an afternoon wiring the thing in.
Post #287081 2nd Dec 2013 7:15pm
kipperthedog
I am loving that temporary fix!
Post #287084 2nd Dec 2013 7:25pm
I made one up for my 110 after the switch melted.
Used a couple of relays. Fortunately I also had an old bulkhead loom, so could chop off the socket (off of the main loom) and along with the plug off of my melted switch, had a truly plug & play loom.
I used the main 12v light feed (which is the thick brown wire), to feed both relay switch contacts (pin 30), and also to feed the normal brown that goes to the headlight switch.
From said switch, there is red (sidelights IIRC), and blue (headlights), each of these goes to one of the relays (onto one side of the coil, pin 86), both pin 85's can be joined together then earthed to a suitable point.
So when you now switch the headlight switch, first position one relay will energise, second position, the other relay will energise.
Now, there will be a red and blue floarting about, waiting for a power feed to be connected. These will connect to pin 87 on each relay, obviosuly using the correct relay for the colour wire.
There is plenty of room up behind the dash to fit these two relays together with the cable. I'll take some pics of mine at some point and post them up.
I did notice the lights were slightly brighter and less yellow with these relays... they're a far better switch than the cr@ppy job that comes as standard.
Post #287098 2nd Dec 2013 7:40pm
mrd1990
Thanks for advice, I think I'll completely redo the headlight wiring at some point and stick the relays in the battery box or under the wing - A new cable direct from battery to lights too, this way I can upgrade the bulbs
In the mean time, found a 25amp toggle switch that fits perfectly. Rated for 25 amps (300w). Has a nice solid feel to it so hopefully it will keep me out of trouble until I get time to rewire everything, the big stoke better not fail me too..
Post #287114 2nd Dec 2013 8:07pm
Diablo
I did mine the other week - stuck it in a waterproof ABS box under the N/S wing
Used the original wiring to the n/s light as the 'switch' side of the relays.
Post #287119 2nd Dec 2013 8:15pm
excossack
Booked a week in Pitlochry in Jan 2014. LR content going in the 110! should be a good run of around 300miles one way! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #287134 2nd Dec 2013 8:45pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
just fitted my buckets seats from csk (killer90). Excellent deal done and the seats are really good, look just like top end corbeaus or recaros but are cheaper.
photos to follow shortly in the gallery. Bow down Thumbs Up
Post #287243 3rd Dec 2013 7:10am
something happened to my reversing light, i suspect water and forest from the weekend ... checked the bulb, that's ok, tow electrics are my next port of call.
Post #287252 3rd Dec 2013 8:24am
Caterham
found the time and courage to fix something that wasn't broke.......... Confused
fitting new hand brake cable.....hopefully will let you know later if I've succeeded?
and just before I start on that I'm gonna go pick up my new map sensor to see if that makes a blind bit of difference.
Post #287273 3rd Dec 2013 10:14am
mrd1990
Driving along in the rain today, headlights on and working with the new switch... then the wiper arm flew off Shocked
Post #287430 3rd Dec 2013 9:36pm
Caterham
Early signs are map sensor has fixed engine once and for all. Hand brake cable fitted after losing one of the shoe retaining springs. Spent hours looking for it and driving round for a replacement to no avail. Ian irb offered to help but I eventually found it had only dropped behind the shoe and not sprung across the drive Embarassed
Anyhow the cable is fixed just need to adjust tomorrow and refit prop.
It's been an opportunity to spray some acf50 here and there while I was under the car.
Thumbs Up
Post #287485 3rd Dec 2013 10:11pm
