Home > Puma (Tdci) > Contaminated fuel
Page 1 of 6 123456>
Contaminated fuel
Last weekend my Puma spluttered to a halt with a blocked fuel filter. Draining some fuel from the filter got it running again, and emptying and refilling the filter a few times got me home on Sunday without a hiccup.
Since it was a little overdue for a filter change anyway I fitted a new filter on Tuesday morning and hoped that that would be the end of it.
Unfortunately this morning it has spluttered to a halt again (once again draining some fuel from the filter has allowed me to get to work), but I am now forced to the unsavoury conclusion that the ESSO garage I filled up at last Thursday sold me 14 gallons of contaminated diesel. Big Cry
Clearly I need to drain, flush and refill the tank as a matter of urgency, and since I know others have had similar problems in the past I wondered if anyone has any advice on the easiest way to do this. At present there are probably about 8 gallons in the tank which will have to be got rid of.
The fuel drained out of the filter is completely free of water if held to the light looks as though it has coffee grounds in suspension. Several lumps of crud (like clods of coffee grounds) also came out of the filter. I've never seen anything quite like it before, not good at all, especially since it must have come from one of the larger and busier garages in the area.
Post #283956 21st Nov 2013 11:35am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Black/brown sludge, normally indicates bacteria present. You'll need to thoroughly clean tank and pipes with a detergent before refilling. Best way to do this is to drop the tank, a pain but easier than trying to do it in situ.
Steve
Post #283961 21st Nov 2013 12:01pm
munch90
The bacteria in diesel grows of feeds on the surface of water present in bottom of tank .. black brown sludge is water full of bacteria.. you can get a additive (enzyme treatment) to kill and prevent regrowth .. also some have a detergent to disperse small amounts of water from the tank ...
all depends how much water is in tank
every tank gets a small amount of water in it due to the heat of the diesel returning to tank (fuel and tank cooling contracting and drawing in cold damp air same thing as why exhaust has always got small amount of water in it but exhaust drys out with good run
small amounts of water in tank is more common now due on later cars running high pressure pumps returning a lot of warm fuel to tank
and the adding of bio fuel to modern diesel has a great effect on diesel bacteria
but the real bad bad bit is the bacteria is very very corrosive and that's another reason why modern cars have plastic tanks and fuel lines
I have seen it eat through new 45 gallon drums in a matter of weeks
Post #283963 21st Nov 2013 12:18pm
Intersting, thanks.
What sort of detergent should I use?
There was no indication (not to me, anyway) of water in the stuff that came out of the filter - I let it stand in a clean jar for quite a while to see if water precipitated from the fuel and there was no indication that it did, just a hazy mass of little cruddy specs like coffee grounds.
I was planning to drop the tank, empty it, then slosh rinse it with clean diesel before refitting (and of course change the filter again). Do you think this will be suffient?
If the pipe from the tank to the filter is drained, will pre-filling the filter with clean fuel (as you would when changing the filter) be enough to prevent air problems, or is it likely to need priming with a bulb?
Post #283973 21st Nov 2013 12:45pm
Naks
Remember, you will also have to clean out the fuel pickup as well, it is probably all gunked up. --
Post #283980 21st Nov 2013 1:03pm
SteveG
Sorry third hand knowledge for me, just know people at local farm that had this issue in their tanks. They had a specialist in to treat tanks and two affected vehicles. I'll ask for name of specialist and if they know type of chemicals used, but this is in Suffolk, so may not be useful for you. For the storage tanks they didn't drain and treated in situ, but vehicles they did drain and clean.
Might also be worth a google for number to call to a specialist and have them recommend a tried and tested solution. I suspect a call to one of the major bio diesel equipment suppliers would yield good results too.
Steve
Post #283987 21st Nov 2013 1:28pm
munch90
blackwolf wrote:
Intersting, thanks.
ok saying water is maybe extreme but moisture yes
Best to clean out properley by removing tank all depends on how much is in there
if you sqoush the coffee ground they feel like plastozine
if you taking tank out then I would flush with clean diesel to remove large bits then fill with clean diesel after refit then get a fuel additive to kill and dissolve diesel bacteria remaining then change filter a few times.
yes will get few air locks
I use 12v small electric pump (facet style) to flush lines from clean diesel container
remember diesel has a small amount of deterngent already added to remove small amounts of water ( make it dissolve in fuel)
warning its going to be messy job
you need a additive for diesel bacteria not just redex or something
sorry about spelling in middle of job
Post #283989 21st Nov 2013 1:34pm
Glynparry25
To be honest the trick will probably be to get a specialist to do it- just for the piece of mind. They should also guarantee the work so you don't fill the next tank up and still have problems resulting in more contaminated fuel. I think the specialist places charge about £100-200 and takes 1-2hrs for a complete system drain and clean and some clean fuel back in your tank. Either ring AA/ RAC or enquire in your local garage for the local ones.
Also: If you only ever use the same garage- report it. If lots of people have had the same problem from the same time, and it has been proven that the garage had contaminated fuel they will be liable for the cost to rectify the system/ re fill your tank. Also might also be an idea to check your fuel tank breather- might be letting small amounts of moisture/ contaminants getting in.
Coming up to the colder months contaminated fuel filter/ lines could cause you all sorts of problems (as I found with Cypriot fuel that waxes at -5 degrees C...... not good when spending a long weekend snowboarding!!).
Glyn Dog Sheep
Post #283992 21st Nov 2013 1:57pm
I am trying to locate a local source of Wyyn's fuel biocide, which seems to be the sort of stuff I need.
I only ever tend to fill up in three places as a matter of routine, two are major Shell stations and one a major ESSO. As far as I can tell from the timings, it is more likely to be the ESSO than anywhere else if indeed that is the source of the problem.
My breather seems OK, and is certainly no different to how it's been for the last four years. I did have a perished breather on the filler neck (as posted elsewhere on this forum) but it was quite a while ago and seems unlikely to be the cause. It is possible however that it allowed more moisture in the tank than normal. I don't know how long it takes for the microbes to multiply (although according to one website, a single cell of the diesel bug - Pseudomonas aeruginosa - can under ideal conditions grow to an 11kg biomass in 24 hrs!)
Thank you to all who have provided advice sofar.
Post #284000 21st Nov 2013 2:48pm
munch90
could well be the start of problem ... there was a make of car years ago used to same thing clip would rot then as rear wheel turned used to spray water on to pipe and where clip had rotted and broke water would get in tank slowly (these were petrol ) all we used to do was repair pipe suck out tank and fit filter inline under bonnet then add a additive (dertergent ) think it was called something like dry fuel when get owner to come back couple of times to drain filter
Post #284005 21st Nov 2013 3:08pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Wynns still sell it , halfords stock it absorbs water
Just pour in , and it burns it off smells like a paraffin burner for a few miles
Post #284009 21st Nov 2013 3:21pm
Advanced Factors
Site Sponsor
United Kingdom 1994 Defender 90 V8 Petrol SW Corris Grey
We have stock
http://www.advancedfactors.co.uk/10601-fuel-biocide-4870-p.asp Paul Redding
+44 (0)23 8052 2760
Site Sponsor for Aftermarket Parts
Post #284014 21st Nov 2013 3:30pm
Cakey
Hi Steve
Just a note the new night breakers are night and day Rolling with laughter better than the old bulbs .
With the crystals plenty of light
Thanks again
Mike
Post #284015 21st Nov 2013 3:33pm
Caterham
coffee grounds......
thats what I had .....
a new filter from Steve, replaced fuel breather under warranty (not sure the coffee grounds weren't bits of rubber in hindsight?).
to be fair the replaced hose meant tank out so this may have been cleaned in the process?
as said before all good now. Thumbs Up
good luck,
Post #284016 21st Nov 2013 3:42pm
Boringoldgit wrote:
We have stock
Steve, that's good to know. If I can't get any locally I may have to blast over tomorrow to get some from you, you're not that far away (from Poole). Do you have Puma fuel filters in stock?
Thanks.
Post #284017 21st Nov 2013 3:45pm
Page 1 of 6 123456>
