![]() | Home > Maintenance & Modifications > Bigger tyres for the look? |
| pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
Hi have 265's on my saw tooth's think they are perfect size as just inside arches I think 285's would be on outer limits & you would get more crud up the side - will take a photo taler when light & post what a 265 looks like from the front & side if it helps unless you already have 265's
| taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 625
If it is just for looks then fit 265's and spacers
Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
265/85/16's with spacers on a 90, can rub rear wheel arch when off road
| Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320
Yes please mate that would be great |
That says to me Steve that I should go max a 265 and no spacers? Also if I was to to do this would you still be interested in my good years or what sort of price would you think I could get for them?, never been off road in them aswell? |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Remember the Xtech offset is different to Boosts so 30mm spacers will look silly IMHO
You have a PM |
| johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459
265 75 16 or go for 255 85 16
Standard Sawtooths with 265's - Any wider & you are outside the arches & a very dirty defender - Mine is bad enough
Click image to enlarge Click image to enlarge Click image to enlarge Hope it helps 2020 P300 HSE |
| alfred. Member Since: 25 Jun 2012 Location: Brindisi - Puglia Posts: 37
Hi pjb, your shocks are original? Or you have changed the height? DEFENDER 110 SW Puma 2.2 Corris Grey "ROKKO TORPES II"
hi all original - as a hard top springs are quite hard & need some weight in the back
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
How wide are the 'sawtooth' alloys? You shouldn't go over 265 width on the regular LR alloy wheels (7" wide) as it goes out of the tyre manufacturers specification..... But many have done it without any problems
Glyn |
| RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2032
here's mine, these are 265/70's on Predator alloys and certainly look chunky and give it a purposeful stance.
Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
| Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824
Yes but are predator alloys not 17" x 8" with a 20mm offset
