![]() | Home > Puma (Tdci) > Poor performance after corners |
Turbo actuator rod sticking?? Pov.spec,ftw. 2006, 110,TD5.
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707 ![]() ![]() ![]() |
Ooh .. Sounds expensive .. How can I check it and fix if necessary? 2008 Defender 110 XS SW - M57N2 / 8HP70X
Usually spray lube on the rod and slide it in and out but DON'T twist the rod,5 second job.There may be carbon built up inside so you can try a diesel additive.
Video of rod and wots to lube.Or Google;lubricate, turbo wastegate actuator rod. Pov.spec,ftw. 2006, 110,TD5. |
If it only does it after a bend or corner and your sure it's ok on straight road when you put foot down then its got to be drawing air in diesel in the tank , if you fill tank up does it stop doing it
It does it on a full tank and when nearly empty
I'll give the actuator a clean. I have checked and have a fault code relating to a brake switch. Could this be connected? 2008 Defender 110 XS SW - M57N2 / 8HP70X |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Water trap checked on the bottom of the fuel filter for water in fuel ?
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Check the turbo modulator harness on top of the engine.
I checked the fuel filter and all seemed to be okay. I read that there was an upgrade to the engine wiring loom for the turbo and egr .. Does anyone have any info on this? .. I suppose my issues could be electrical 2008 Defender 110 XS SW - M57N2 / 8HP70X
would it not do it in a straight line then as well as 'after a sharp corner' unless wiring is moving on cornering ! |
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 ![]() ![]() ![]() |
Although on a Puma I would probably not work the rod in and out as the actuator is electronic not a vacuum job as tradtional turbo diesels have. Jonno |
IanW Member Since: 12 Jun 2011 Location: Gloucestershire Posts: 172 ![]() ![]() ![]() |
Sounds very similar to the problem with our 110. EGR was changed and I thought that had fixed it. M J Fews fitted a new engine wiring harness part number LLRO20663 which apparently is a modified harness last Friday, and that appears to have fixed the problem. The part cost £18-14 plus vat. One wife - livid
LRO20663 is the Turbo Modulator Harness link kit
Thanks for the great information .. I'll order the part up from the local dealer. (Is there a recommended online source for genuine LR parts?) 2008 Defender 110 XS SW - M57N2 / 8HP70X
Don't know about this particular part, but M J Fews ebay shop was the cheapest for the EGR from the research I did. One wife - livid
