Home > Puma (Tdci) > Poor performance after corners
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi
My puma 110 SW is suffering from poor performance after a sharp corner. Typically this is when trying to accelerate out of a roundabout (I live in Milton Keynes so you can imagine this happens frequently! Sad ). The engine sounds muffled and feels 'heavy' almost with a misfire feeling. After a little while it will clear again and off we go.!
Any ideas? (I changed the EGR today as I suspected that was the issue, but it's still there)
Thanks 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #282509 15th Nov 2013 8:07pm
jimbob7
Turbo actuator rod sticking?? Pov.spec,ftw. 2006, 110,TD5.
Post #282555 15th Nov 2013 10:57pm
carrotbay
Ooh .. Sounds expensive .. How can I check it and fix if necessary? 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #282556 15th Nov 2013 11:00pm
jimbob7
Usually spray lube on the rod and slide it in and out but DON'T twist the rod,5 second job.There may be carbon built up inside so you can try a diesel additive.
Video of rod and wots to lube.Or Google;lubricate, turbo wastegate actuator rod.
Post #282560 15th Nov 2013 11:14pm
munch90
If it only does it after a bend or corner and your sure it's ok on straight road when you put foot down then its got to be drawing air in diesel in the tank , if you fill tank up does it stop doing it
Post #282564 15th Nov 2013 11:32pm
carrotbay
It does it on a full tank and when nearly empty
I'll give the actuator a clean.
I have checked and have a fault code relating to a brake switch. Could this be connected? 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #282565 15th Nov 2013 11:36pm
bell-auto-services
Water trap checked on the bottom of the fuel filter for water in fuel ?
Post #282573 16th Nov 2013 12:17am
Lorryman100
Check the turbo modulator harness on top of the engine. Thumbs Up
Post #282925 17th Nov 2013 6:12pm
carrotbay
I checked the fuel filter and all seemed to be okay. I read that there was an upgrade to the engine wiring loom for the turbo and egr .. Does anyone have any info on this? .. I suppose my issues could be electrical 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #282924 17th Nov 2013 6:12pm
munch90
would it not do it in a straight line then as well as 'after a sharp corner' unless wiring is moving on cornering !
Post #282936 17th Nov 2013 6:29pm
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
Although on a Puma I would probably not work the rod in and out as the actuator is electronic not a vacuum job as tradtional turbo diesels have.
Jonno
Post #283064 17th Nov 2013 10:22pm
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
Sounds very similar to the problem with our 110. EGR was changed and I thought that had fixed it. M J Fews fitted a new engine wiring harness part number LLRO20663 which apparently is a modified harness last Friday, and that appears to have fixed the problem. The part cost £18-14 plus vat. One wife - livid
Post #283250 18th Nov 2013 6:53pm
Lorryman100
LRO20663 is the Turbo Modulator Harness link kit Thumbs Up
Post #283257 18th Nov 2013 7:03pm
carrotbay
Thanks for the great information .. I'll order the part up from the local dealer. (Is there a recommended online source for genuine LR parts?) 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #283332 18th Nov 2013 9:56pm
IanW
Don't know about this particular part, but M J Fews ebay shop was the cheapest for the EGR from the research I did. One wife - livid
Post #283337 18th Nov 2013 10:02pm
