Home > Technical > Higher output windscreen washer pump? |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Find a headlight washer pump.
9th Nov 2013 12:48pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
what size pipe did youuse to big a diameter will give low pressure. 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
9th Nov 2013 3:25pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1731 |
try wiring another standard universal washer pump in series in the line, should boost pressure and flow.
Keith |
9th Nov 2013 3:52pm |
chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264 |
Pipe diameter same as standard. Standard pump seemed weak just with two jets!! Will look into light washer pump. Thanks all.
9th Nov 2013 4:04pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6047 |
I've wondered the same thing. Fitted the twin nozzles to my 110. it's "OK", but just that. nothing mega.
9th Nov 2013 6:12pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2091 |
TD5 on washer pumps are available in a higher pressure variant, with a red top IIRC, used for the rear screen. I'm sure google will come up with the numbers. I have 2 red tops on my bottle and the pressure through 2 sets of jets is fine.
HTH Mo The Land Rover 90 - Many are called, few are chosen. |
9th Nov 2013 6:53pm |
Hello Mo, Long time no see!!
Good tip that, I'll have a look and see what the number is. |
9th Nov 2013 8:19pm |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 |
DMC100540
9th Nov 2013 9:25pm |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 226 |
Fit a Webasto Hotshot...
At aproximately GBP 60,- (on discount) you get hot water and higher pressure. Q. |
19th Nov 2013 10:05pm |
fitted new red top pump Sunday works like jet wash now
20th Nov 2013 9:00pm |
Pleased to hear it
21st Nov 2013 7:29pm |
jimsadventure Member Since: 10 Nov 2013 Location: edinburgh Posts: 199 |
Where can you get them for £60 fella , i would be interested |
24th Nov 2013 12:49am |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
clean the check valve on the firewall Augusto
Defender 110 TD5 2001 Discovery 4 TDV6 |
24th Nov 2013 1:42am |
