![]() | Home > Technical > Higher output windscreen washer pump? |
Find a headlight washer pump.
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
what size pipe did youuse to big a diameter will give low pressure. 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
try wiring another standard universal washer pump in series in the line, should boost pressure and flow.
Keith |
chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264 ![]() ![]() |
Pipe diameter same as standard. Standard pump seemed weak just with two jets!! Will look into light washer pump. Thanks all.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6215 ![]() ![]() ![]() |
I've wondered the same thing. Fitted the twin nozzles to my 110. it's "OK", but just that. nothing mega.
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2395 ![]() ![]() ![]() |
TD5 on washer pumps are available in a higher pressure variant, with a red top IIRC, used for the rear screen. I'm sure google will come up with the numbers. I have 2 red tops on my bottle and the pressure through 2 sets of jets is fine.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Hello Mo, Long time no see!!
![]() Good tip that, I'll have a look and see what the number is. |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 ![]() ![]() ![]() |
DMC100540
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 ![]() ![]() ![]() |
Fit a Webasto Hotshot...
At aproximately GBP 60,- (on discount) you get hot water and higher pressure. Q. |
fitted new red top pump Sunday works like jet wash now
Pleased to hear it
![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
jimsadventure Member Since: 10 Nov 2013 Location: edinburgh Posts: 199 ![]() ![]() ![]() |
Where can you get them for £60 fella , i would be interested |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
clean the check valve on the firewall Augusto
Defender 110 TD5 2001 Discovery 4 TDV6 |
