![]() | Home > Technical > Turbo under boost |
| tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436
Skye_Rover,
am i right concluding that when placing a new turbo the ECU needs to relearn, when replacing the harness this is not necessary And then maybe a question for the BAS, does the ECU have a build in learn cycle? does this run automatic? or how can we without having LR-diagnostics perform the relearn? I guess when putting an uprated turbo the same applies, but never saw it mentioned before |
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
The ecu know the poston of the turbo veins and adjusts as needed.
https://www.defender2.net/gallery/albums/u...0turbo.doc Pete |
we need more guys like you on here educating us |
| willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 204
Ive got a MY11 90 and i have the same fault codes and feels down on power. Its out of vin range though.
How complicated is it to DIY if i find im suffering with this problem? I use it for towing so would appreciate some help. |
