Home > Puma (Tdci) > Puma 2.2 Turbo Hose |
RustyM Member Since: 28 Oct 2013 Location: Africa/The Med Posts: 222 |
Do none of the nice companies on here offer an aftermarket performance replacement hose
4th Nov 2013 3:03pm |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 614 |
Ah, just noticed that BAS do a hose set for this. I somehow thought that it was only for the hose from air filter to turbo.
Ordered. |
4th Nov 2013 4:10pm |
And received - that was quick.
They look very substantial - much better than the flimsy Land Rover original. Hopefully this should stay in place once fitted. |
6th Nov 2013 11:59am |
Any chance of a picture please?
Thanks M 90 & Wolf 110 XS Previously owned SI SII SIIa SIII & Light weight (air portable) |
6th Nov 2013 5:42pm |
Click image to enlarge Much more substantial than the flimsy thing that I have had to reconnect many times. When I get to replace it, I'll take a photo of the two side by side. It also came with two other hoses for other connections to the intercoller that I might also use depending on how lazy I am/ easy it is to change these. I haven't heard of the others popping off. |
6th Nov 2013 11:49pm |
Did this today - pig of a job. Access is tricky - first instruction from the workshop manual is "drain and store refrigerant from AC". I cannot do this, nor refill later so had to spend all day working around a very inconvenient AC line that then didn't allow air filter box to be removed. Also, the new silicone hoses are thicker than the old rubber ones and the Mikalor clamps I used are larger than the old jubilee clips, so even trickier to refit than removing the rubber ones.
Hers is a comparison shot of the original and BAS hoses side by side: Click image to enlarge Here is the new silicone turbo hose fitting snugly all the way on to the turbo outlet as it should: Click image to enlarge Only problem now is I get a whistling at higher revs. Not sure if this is an air leak when the turbo engages or something rubbing on the belt when the engine moves under load. Looking forward to taking it all apart and doing it again. |
17th Nov 2013 10:50pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Nice pictures
Make sure your steel pipe is well clear of the pully on the engine. If you do have the tools to take of the viscous fan it helps in letting you get your hands down to the turbo side intercooler pipe. Regards Pete |
18th Nov 2013 12:25am |
Hello Pete
Ah, just bought myself a viscous fan spanner to replace the dodgy one on my V8. Didn't think about removing it on the Puma. Might give me a little more flexibility to bend the plastic shrouds around a bit. |
18th Nov 2013 1:27am |
once removed it allows you to hold bach the plastic fan cowle which gives you a little more room.
18th Nov 2013 10:02am |
GEllis Member Since: 21 Nov 2013 Location: Cornwall Posts: 58 |
My two month old 2.2 UTSW that's only done 2.5k miles split a hose last night. Off to the dealers this morning who to be fair gave first class service. Straight into the garage on the ramps fault spotted demo defender provided for my use and promise to have the faulty part sorted by Thursday.
Should not have been a surprise as we have other 2.2tdci's and they have all done the same! A little unfortunate it happened this week I rely on these vehicles for my business and can't afford to have them off the road when the weather is bad - Bad weather for us = demand in services. |
5th Feb 2014 5:18pm |
canterkid Member Since: 16 Mar 2013 Location: norfolk Posts: 13 |
FIRST TIME TOWING TRAILER WITH 2.2 DEFENDER , O.K ON UNLADEN TRIP ,BUT ON RETURN JOURNEY WITH LOAD AND A TOWING WEIGHT OF APPROX 2.5 TONS AND ONLY HAVING TRAVELLED ABOUT 11 MILES YES ONCE AGAIN TURBO PIPE SPLIT ! L/R ASSIST CALLED OUT TOO FIX ,HE SAID THE PROBLEM IS THAT PIPE HAD NOT BEEN FITTED CORRECTLEY BY DEALER THE WHITE MARK ON PIPE SHOULD BE IN LINE WITH THE WHITE MARK ON INTERCOOLER FITTING,SO THAT IT IS LESS STRESSED.THIS IS NOW THE 3RD TIME THAT PIPE HAS SPLIT OR CAME OFF ALL THIS IN LESS THAN 1500 MILES,NENER HAD A PROBLEM WITH ORIGINAL FACTORY FITTED PIPE,PROBLEMS ONLY OCCURED AFTER RECALL. GOING IN TO DEALERS ON WED TO HAVE A NEW PIPE FITTED AGAIN, AS L/R CHAP MADE A GOOD TEMPOARY REPAIR THAT GOT ME HOME STILL TOWING TRAILER. FOUND DEALERS UNHELPFUL ON PHONE TRYING TOO SAY THAT IF THIS WAS NOT A WARRENTY JOB I WOULD BE CHARGED,THEY MUST THINK I WAS BORN YESTERDAY
8th Feb 2014 11:08pm |
Why the 'shouting?' Makes it more difficult to read too! If you go through life with your head in the sand....all people will see is an ar5e!!
9th Feb 2014 9:37am |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 606 |
I'd like to know this too. I am replacing all the pipes for BAS blue silicone hoses (including the new Airbox to Turbo hose). What size Mikalor clips do I need? |
12th Apr 2017 12:30pm |
2hooky Member Since: 30 Dec 2014 Location: cotswolds Posts: 28 |
hi there,
I went through around 3 lots of hoses and it seems LR modified them during the periods. However, the problem in the end was a split intercooler - not sure if anyone else suffered this? |
28th Apr 2017 11:39am |
