Home > Maintenance & Modifications > Td5 dash illumination
grafty99
I know that the illumination of the td5 dash is absolutely fine, but I thought it could be made to look 'cleaner' so I sourced some LEDs and this is the result, brighter than standard, not too bright but much more modern looking, yet to do the heater control lights and will be dismantling the clock to install brighter LEDs to match the rest of the dash Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #279779 5th Nov 2013 7:50pm
grafty99
Picture in gallery 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #279781 5th Nov 2013 7:52pm
excossack
I'd be interested in how you get the clock open to do the bulbs as that's the only clock that I haven't changed to LED 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #279810 5th Nov 2013 8:46pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Wow that looks really good! 1998 110 300Tdi White Hard Top
Post #279820 5th Nov 2013 9:11pm
jont
2006 Defender 90 Td5 XS CSW Santorini Black
What LEDs did you use and where from ?
Jon
Post #279821 5th Nov 2013 9:13pm
Tiger
As above ?
Post #279822 5th Nov 2013 9:14pm
grafty99
Thanks for the nice comments, I got the LEDs from crazyleds.co.uk (no affiliation) I have already had the clock apart to get rid of the orange filter for the needles, just need to get the correct high powered SMD LEDs, excossak do you have any pictures of your dash? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #279824 5th Nov 2013 9:17pm
grafty99
To do everything but the clock you need 2 x 509t LEDs and 4 x 286 LEDs Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #279827 5th Nov 2013 9:18pm
grafty99
286-T5-3xPLCC-2 is the type for the fuel temp and heater control illumination, I haven't done my heater controls yet so can't comment on how good that'd be. They do different colours, I went white but green would work if you wanted green needles, Also red would be pretty funky Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #279829 5th Nov 2013 9:22pm
excossack
My dash as requested.
and
Regards
John M0VAZ
Post #279862 5th Nov 2013 10:16pm
grafty99
looks exactly the same, no surprises there I suppose! which leds did you use ? have you done the heater controls? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #279892 5th Nov 2013 11:04pm
excossack
I just used white LEDS from Ebay and yes I have done the heater controls. Just need to suss out the clock next as it appears sealed.?
I find the LED's an improvement over the standard bulbs. 1999 Defender TD5 110
Regards
John M0VAZ
Post #279964 6th Nov 2013 9:59am
grafty99
An improvement for sure Thumbs Up the clock does come apart! very gently remove the plastic bezel from the front; Then the plastic window. There are two tabs in the threaded section of the body of the clock, bend them back and pull the inner workings of the clock out by the centre of the needles. There sure four LEDs in there all facing the spindle for the needles. I'm going to replace them with brighter ones and see if that does the trick. If not I'll be looking at putting more LEDs in to get it to match Thumbs Up
Just had a thought, I have also done my cigar lighter socket Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #279993 6th Nov 2013 11:39am
excossack
Excellent - thanks for the heads up. Will have a look at the weekend. I replace my Ciggie socket with a blue sea one and also added a blue sea dual USB socket 1999 Defender TD5 110
Regards
John M0VAZ
Post #279996 6th Nov 2013 11:43am
grafty99
What's the advantage to a blue sea cigar lighter socket? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #280235 7th Nov 2013 1:18am
