![]() | Home > Maintenance & Modifications > Td5 dash illumination |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I know that the illumination of the td5 dash is absolutely fine, but I thought it could be made to look 'cleaner' so I sourced some LEDs and this is the result, brighter than standard, not too bright but much more modern looking, yet to do the heater control lights and will be dismantling the clock to install brighter LEDs to match the rest of the dash
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Picture in gallery 2002 90 Td5 Station Wagon
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
Wow that looks really good! 1998 110 300Tdi White Hard Top
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 ![]() ![]() |
What LEDs did you use and where from ?
Jon |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
As above ?
Thanks for the nice comments, I got the LEDs from crazyleds.co.uk (no affiliation) I have already had the clock apart to get rid of the orange filter for the needles, just need to get the correct high powered SMD LEDs, excossak do you have any pictures of your dash? 2002 90 Td5 Station Wagon
To do everything but the clock you need 2 x 509t LEDs and 4 x 286 LEDs
286-T5-3xPLCC-2 is the type for the fuel temp and heater control illumination, I haven't done my heater controls yet so can't comment on how good that'd be. They do different colours, I went white but green would work if you wanted green needles, Also red would be pretty funky
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
My dash as requested.
![]() and ![]() Regards John M0VAZ Econet Station 48 no clock |
looks exactly the same, no surprises there I suppose! which leds did you use ? have you done the heater controls? 2002 90 Td5 Station Wagon
I just used white LEDS from Ebay and yes I have done the heater controls. Just need to suss out the clock next as it appears sealed.?
I find the LED's an improvement over the standard bulbs. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
An improvement for sure
![]() ![]() Just had a thought, I have also done my cigar lighter socket ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Excellent - thanks for the heads up. Will have a look at the weekend. I replace my Ciggie socket with a blue sea one and also added a blue sea dual USB socket 1999 Defender TD5 110
What's the advantage to a blue sea cigar lighter socket? 2002 90 Td5 Station Wagon
